Question Upgrading PC parts
Jan 6, 2019
5
I'm thinking of upgrading some parts of my PC but honestly im not sure which part i should upgrade for now due to budget limit i cant change alot of things, i thought that my GPU is kind of weak and it should be my first upgrade. any suggestions ?
PC specs:
GPU: AMD Radeon RX 580 4 GB
CPU: Ryzen 5 2600
Motherboard: Asus prime B350 M-A
Memory Ram: 24 GB 2400 mhz
SSD: 240 GB kingston
i think my hard drive is not working im not sure if that will affect my pc performance?
Thank you!
What do you want it to do better? What resolution & Hz is your monitor?
The first thing that stands out is 24gb RAM 2400mhz. Is this actually in a configuration that runs in dual channel? 2400 is slow for Ryzen and directly impacts performance.
What problem are you having with your HDD?
monitor is 144 Hz, i would like to stream fortnite on 1080p. after installing the SSD i formated my PC. for some reason my HDD is not showing up. what do you mean by duel channel?
