Hey,
I wanted to upgrade my pc... well.... I wanted to do more of a 'soft' upgrade rather than another scratch build that'll cost a bomb. I was given a brand new Threadripper 1950x in early June and haven't had time to actually look into it but I have a few questions I wanted to ask about what I can keep from my old build and what I absolutely need to upgrade (only made 1 build so sorry if the questions are obvious ). My current set up was made in early 2016 and is as follows:
CPU - 6th gen i7 6700k, 4 core, 8 thread
RAM - Kingston HyperX Fury 2133 MHz DDR4 32GB RAM
MOBO - ASRock Fatal1ty Z170 Professional Gaming i7
PSU - Corsair CP-9020072 Platinum Series 750W
CPU Cooling - Noctua NH-U14S with 2 AF-A15 140mm fans (love them)
SSD 1 - Samsung 850 500GB SSD - Running Windows 10
SSD 2 - Samsung 860 1TB SSD
HDD - Seagate Baracuda 4TB
GPU - Geforce GTX 1080Ti
Corsair 780T Graphite Tower
I'm open to suggestions, but for the MOBO upgrade, was thinking maybe the MSI X399 SLI PLUS. But apart from that I'm not sure and wanted to get a little help on these questions:
Would I need to upgrade my PSU to something that can handle the Threadripper 1950x? I'm not planning on overclocking/gaming, but want to utilise the 16 cores (from my modest 4 cores) for intense 3D rendering work stuff
Would my current Noctua Air cooler be fine for the Threadripper or would an upgrade be needed? I prefer Air coolers to AIO, though I've heard water is best, again if you plan to over clock. Not a massive water cooler fan, mainly for the noise it makes
Finally (and importantly) would I need to upgrade my PC Tower?!
Any help and advice would be very much appreciated
