Urgernt Printing from DOS problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I am running Windows XP Home addition with SP2 installed. My PC is connected
to LAN with 1 server and shared printer.
I have read so many questions about how to do this with most responses
directing everyone to go to the Print To DOS site. That's all great if you
know when to put \\, / \ : but I have followed these instructions until I'm
blue. Here is how I entered the command from the DOS window: net use
lpt1: \\srv01\Kyocera FS-1010N /user: \\srv01/BOB /persistent:yes
Note the spaces! My Server name is srv01, the printer (shared) name is
Kyocera FS-1010N. I'm Bob. So what am I doing wrong?
Thanks for your help!
Bob
lpt1: \\srv01\"Kyocera FS-1010N" /user: \\srv01/BOB /persistent:yes
You need to " " the share name when it has spaces or just change the
sharename so there are not spaces. The DOS window require the quotes even
when listing files with dir in the cmd window.
you might need to specify the password but if you are logged in as BOB, I do
not think you need to specify user name
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
;kbhowto]http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
This posting is provided "AS IS" with no warranties, and confers no rights.
"Rednosebob" <Rednosebob@discussions.microsoft.com> wrote in message
news:B418CE91-2DFA-4914-A803-C78B1A87C412@microsoft.com...
connected
you
I'm
> Bob
When I enetered the command, using NET USE ... I recieved the following
System error 66 has occurred.
The network resource type is not correct.
> Alan Morris
> connected
> you
> I'm
> > Bob
Error 66 means the network share cannot be found. Is the firewall disabled?
If you type net share can you view the printer sharename
net share
Share name Resource Remark
C$ C:\ Default share
E$ E:\ Default share
IPC$ Remote IPC
HPDesign npi94e8ed Spooled HP DesignJet 750C+ (E/A0) by HP
nec NPI3fdb74 Spooled nec
RicohAP3 IP_157.56.28.57 Spooled RicohAP3800C PS
Xerox55P XRX0000AA6A4C56 Spooled Xerox 55 PS
Save some time here, change the sharename to printer. Get rid of the
spaces until you get this working. You can change this back later after you
get the
net use lpt1: \\ntprint\nosharemane
Alan Morris
news:21903CCF-F249-4EC8-AF8A-99DD236F4AF6@microsoft.com...
> messages:
even
I do
> > Alan Morris
rights.
> > connected
if
> > you
until
> > I'm
use
is
> > > Bob
I'm still not getting there. Below is what I enetered and what was displayed:
C:\>net share
print$ C:\WINDOWS\system32\spool\drivers
Printer Drivers
IPC$ Remote IPC
SharedDocs C:\DOCUMENTS AND SETTINGS\ALL USERS\DOCUMENTS
Lexmark USB-LexmarkX84-X85 Spooled Lexmark
The command completed successfully.
C:\>
I don't know if any of that makes sense, but one thing I saw was that the
Network printer (Kyocera FS-1010N) was not displayed. But I have to tell
you, I've been printing all morning to it through our network.
Bob
> net share
> IPC$ Remote IPC
> get the
> Alan Morris
> > messages:
> even
> I do
> > > Alan Morris
> rights.
> > > connected
> if
> > > you
> until
> > > I'm
> use
> is
> > > > Bob
An additional note. Assuming I can get the correct commands to work, my DOS
application that I'm using specifically wants to print to lpt1 or ltp2
(apparently hard coded in the software). When I look at Printfil, it doesn't
exactly say it will emulate lpt1 or 2. I did download the program, with no
real success.
I'm not a programmer, just a user and it's extemely disappointing that it
has taken almost a month to solve this problem. And just as disappointing,
Microsoft didn't think about us little guys when they upgraded their
operating systems. I can remember when you bought a computer or an upgrade
it would come with a manual. Difficult at times to totally understand but at
least it was something. Now when you buy a PC or an upgrade you don't get
anything to help you.
Sorry, but I had to vent a little.
> C:\>net share
> Printer Drivers
> IPC$ Remote IPC
> C:\>
> Bob
> > net share
> > IPC$ Remote IPC
> > get the
> > Alan Morris
> > > messages:
> > even
> > I do
> > > > Alan Morris
> > rights.
> > > > connected
> > if
> > > > you
> > until
> > > > I'm
> > use
> > is
> > > > > Bob
Bob,
Printfil can capture port LPT1, LPT2 or LPT3, you just need to select it
into the configuration dialog.
> I did download the program, with no real success.
Which problems did you have ?
Did you try to ask the support team ?
Kind regards,
Davide Guolo
Printfil - Windows Printing System for Applications
http://www.guolo.com/printfil
Odbc4All - Connection to ODBC Data Sources for any Application
http://www.guolo.com/odbc4all
I owe you a HUGE appology. The program that wasn't working correctly for me
was called PrintToDOS. I tested Printfil and it worked great. For those who
might be having the same problems as I was, I highly recommend this software
(Printfil). It is well documented, easy to understand, at least for the
re-directing LTP1 to my USB driven printer.
Thanks again Davide!
Bob
"Davide Guolo" wrote:
> Bob,
> Kind regards,
> Davide Guolo
Bob,
don't worry. I'm glad to see you are happy with Printfil.
You are welcome.
Regards,
Davide.
"Rednosebob" <Rednosebob@discussions.microsoft.com> ha scritto nel messaggio
news:8FAEF1E7-144D-4C67-8009-514B1C67EC5F@microsoft.com...
me
who
software
> Bob
> > Bob,
> > Kind regards,
> > Davide Guolo
