USB 2.0 problem
Tanner
5
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
When Using USB 2.0 Devices. I get error that reads HI-
SPEED USB device attatched to non-HI-SPEED port. The
recommendation is to add a HI-SPEED USB host controller.
How do I do this? Also is this the right step in order to
getting my USB 2.0 to work?
getting my USB 2.0 to work.
Easy your computer does not support usb 2.0 first of all. 2.0 usb is not software. is hardware. buy a pcmcia adapter III and you're ready to use 2.0 high speed. " you'll spend 30 bucks"
If you are using a desktop machine you will need to purchase and install a
USB 2.0 card and ensure you have the WinXP SP1 update installed as this
update has the USB2.0 drivers.
If you have a laptop you will need to purchase a PC Card (PCMCIA). IF you
are buying a PC Card you should buy one with an external power supply. You
also need the SP1 update.
"Tanner" <tanmansprinter@hotmail.com> wrote in message
news:bdff01c4382e$1e52cb10$a401280a@phx.gbl...
Ask Sony as you seem unwilling to supply the model type here..
Mike Hall
MVP - Windows Shell/User
"If hard work were such a wonderful thing, surely the rich would have kept
it all to themselves." - Lane Kirkland
"Dude" <Dude.1qvnhm@news.nospam.local> wrote in message
news😀ude.1qvnhm@news.nospam.local...
> Hi I have a 2003 sony notebook, and I want to get an Ipod. The dude at
> the store says I need a 2.0 USB. I am looking all over and don't know
> if I have it.
> Dude
> Dude's Profile:
> http://extremetechsupport.com/forum/member.phtml?userid=1271
> View this thread:
> http://extremetechsupport.com/forum/showthread.phtml?t=13266
> if I have it.
The specs for your system should state whether your USB is 2.0 or not. If
you don't have a manual handy to look these up, you should be able to find
the information online at the Sony site.
Sharon F
MS-MVP ~ Windows Shell/User
Quick check: Plug a device (such as a USB thumbdrive) that you know is USB
2.0 into your USB port. If you don't get the "Hi-speed device" warning, you
have a USB 2.0 port.
courtney
> if I have it.
> Dude
> Dude's Profile:
> View this thread:
Courtny Cox?
"Courtney" <a@b.c> wrote in message
news:O4mte.136284$sy6.48648@lakeread04...
> you have a USB 2.0 port.
> courtney
>> if I have it.
>> Dude
>> Dude's Profile:
>> View this thread:
