USB Modem Problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a Diamond Supramax USB 56k Dial-up modem installed on an Amd k6-2 500
Mgz computer.
The only way I can get the thing to work is to set my dialing from "Tone" to
"Pulse" but then it will only connect at 31.2 kbps, my ISP is Juno.
Any ideas?
Thanks for any input.
Dave
Does your ISP support higher speeds? Not every ISP does.
Also, depending on the distance to the connecting server, speeds can
descrease/
"Davidt238" <Davidt238@discussions.microsoft.com> wrote in message
news:738FA840-2DCC-4C96-BB6E-741004C4FA8A@microsoft.com...
>500
> Mgz computer.
> to
> Any ideas?
> Dave
Thanks for responding!
I believe my ISP is fine, I could connect at 52 kbps with my Lucent PCI
modem before I bought the USB Modem.
Also, when I try to connect on "Tone" dialing the modem thinks that the line
is busy.
> descrease/
> >500
> > Mgz computer.
> > to
> > Any ideas?
> > Dave
Maybe the "country settings" of the modem are wrong.
Check if there is utility to tweak these settings.
They define how the dial and busy tones look like in different countries.
--PA
"Davidt238" <Davidt238@discussions.microsoft.com> wrote in message news:738FA840-2DCC-4C96-BB6E-741004C4FA8A@microsoft.com...
> Mgz computer.
> Any ideas?
> Dave
Thanks Pavel for responding!
I checked my country setting and it was set to "USA".
Another thing is weird, my PCI modem makes the sounds when logging on but
the USB modem did at first but stopped making them. I have the speaker
settings for both modems set to "On" and "High" for volume.
> --PA
> > Mgz computer.
> > Any ideas?
> > Dave
