Replying to the following message:
....."I'm looking to replace my wired mouse with a wireless one, in this case a Logitech M310 I found at work. However the nano receiver it comes with is lost, and I have two other mouse receivers from different mice. Is it possible to somehow use the Logitech mouse with a receiver that it didn't come with...."
*YES, you are in luck, and it's FREE. Go to:
*NOTE: The USB reciever and mouse must be the same brand i.e.:
Logitech USB receiver + Logitech mouse= SHOULD work.
Microsoft USB receiver + Logitech mouse= will NOT work.
http://support.logitech.com/en_us/software/unifying
and download the software as instructed on the page. All you need to do is UNIFY your available Logitech USB receiver that you have on hand and it should work. Once on the site, remember to identify your Platform and OS, and then proceed with the unification process via thier download.
I had a wireless mouse that I really liked using and the USB receiver was lost some time ago. I had found a USB receiver in a drawer assuming it was from one of my other devices not being used (had no idea what it belonged to.) I did not want to pay for another USB receiver if I could avoid it, so I decided to give the abovementioned method a shot. It worked like a gem. Simple, straightforward instructions, took about 20 seconds, and worked instantaneously. Feel free to email me at:
Personal email redacted by Moderator
if you get stuck, I'd be happy to help if I can.
Best of luck to you all.
