Using AIW Radeon only as capture card
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Hey I have an ATI AIW Radeon 32MB PCI edition card, but I also have a Radeon
9200, does anyone know if it's possible to use my AIW just as a capture
card, I am having problems with trying to set it up
"CheeseFoot" <joel_aw_adams@hotmail.com> wrote in message
news:ayixc.55398$Np3.2456962@ursa-nb00s0.nbnet.nb.ca...
Radeon
Have you tried setting the PCI AIW card as the primary card (the one the
machine uses at boot time)? All In Wonders HAVE TO be the primary card in
order to function fully (with TV capture capabilities). If this doesn't
work, try removing the AGP card and setup the All In Wonder so it works for
your needs, then what happens when you put the 9200 back in? In terms of
drivers, although they both use the same Catalyst set, you'll need to
install them seperately for each card in order to get the correct registry
entries for each - ie you can't just add a Radeon based card and expect it
to work faultlessly using the existing drivers if the Radeon chips are
different (as they are in your case).
Paul
