You may NOT want to use those to connect all your fans to a Molex output from the PSU.
When you connect a fan directly to a PSU output, it receives 12 VDC power ALL the time, so it can only run full speed. Further, since it has no connection at all to the mobo, the mobo cannot tell you the fan speed, nor can it warn you if the fan fails.
Speed control of the fan is one of the features available from a mobo fan header. Normally for each header the options available are:
(a) Automatic speed control - the mobo constantly adjusts trhe fan speed according to heat generated by your changing workload, and it does that by measuring actual TEMPERATURE, either inside the CPU chip for the CPU cooling fans, or on the mobo for the case cooling fans. This is usually the default setting.
(b) Always full speed for max cooling no matter what you are doing (same as if you connect directly to PSU)
(c) Always fixed reduced cooling no matter what you are doing, gives quieter operation at a sacrifice of reduced heat removal.
(d) Custom - similar to Automatic, except you get to specify the fan speed to be used for several temperatures along a "curve".
In addition, a mobo header will display the fan speed in BIOS Setup and through certain software utilities that can run as Windows apps to display while you are working normally. One such utility usually is included on the CD of software and drivers with the mobo. Further, the mobo normally monitors the fan speed signal for FAILURE and can send you a warning of that so you know to fix it. "Failure" may be no fan speed, or may be speed less than some threshold you may be able to specify, dependent on your fan's specs. In this regard, the limitation I referred to above on the use of Splitters is this. The mobo header can only deal with the sopeed signal sent back to it from ONE fan. So when you use a Splitter, only one fan's speed from that Splitter is sent back to the mobo, and you will never "see" the speed of the other, nor have automatic failure detection on that second fan.
