G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hello all,
I have a (sorta) homebuilt system, using a K8V motherboard and AMD 3400+
CPU .... I want to use firewire connections (for my camcorder), however this
motherboard does NOT have firewire connections. (Deluxe yes, Plain ole
K8V no) so I purchased a 3-Port Firewire PCI Host Adapter from
FirewireDirect.com, installed it, booted the computer and there was
no "Found New Hardware" msg from Windows, there is no new entry
in Device Manager (not even one marked "disabled"or something)
The card came with just that ...... the card ... no manual, no instructions,
just the PCI card and the receipt which clearly says "No software needed
for operation"
When I use one of my programs for capturing video (Nero Vision or
Ulead Video Studio 9.0 .... both give the message "No capture device
installed
or detected" (with the camera plugged in and turned on) it's a Canon ZR85 if
that
matters)
I did notice a 4 pin connector on the card, for connecting a power source
that is not
connected to anything but their tech support assured me it does NOT have to
be "that power
connection is just there in case you want to install additional firewire
devices"
At either rate, I have no idea how IEEE94 is supposed to work, what I should
see
(in device Manager) ... in short I have NO clue about anything to do with
Firewire.
I am wondering if someone thinks I have provided enough info to definately
state that the card is defective or if maybe I might have missed something
and
not done something right. (Or maybe this motherboard will not support
firewire of
any kind or something)
I am running Windows XP Pro (sp2). I have swapped PCI slots the card used to
rule that out .. final point is neither System Info or Everest Ultimate
Edition show
this device, or any 'Unknown device" in a PCI slot.
Any ideas?
Hello all,
for operation"
installed
that
matters)
that is not
be "that power
devices"
see
Firewire.
and
firewire of
Edition show
Any ideas?
