[SOLVED] Using Molex to SATA adapters for Corsair RGB Hub
account12312312
5
Hi everyone,
I recently bought myself the Corsair Obsidian 1000D case and I am looking at kitting it out with several fans all with RGB features. The case comes with the Corsair Commander Pro however doesn't come with the RGB controllers that are required for the RGB. Due to the amount of fans that I will be using I believe I will be needing 2 of these RGB controllers however the issue is, due to the amount of hard drives I have, I do not have enough SATA power connectors left. Therefore, I found that there are Molex to SATA adapters as I have not used any of my Molex cables (who does use these things anymore anyway) so I was wondering if I could use one of these adapters to power the RGB controllers.
Thanks in Advance,
Sam
