Using Premier Pro with HD6870
P910607
36
Hi..!
Im going to be using Premier Pro CS 5.5 for video editing on my Pc.
I heard that it is best to have a Nvidia Graphics card as the software in Premier can make use of CUDA graphics acceleration to improve the performance of the Premier software.
This will involve buying a whole new card, but if i keep the one i already have, will i really see any noticeable difference if i upgrade simply for the use of CUDA?
What improvements will i 'actually' see in throwing away my XFX Radeon Hd 6870, and replacing it with a GigaByte Nvidia GTX 560Ti ?..?..?
Is it worth it, i mean, what are the 'real time' benefits here, do they out weight the trouble and cost ill need to invest, the Radeon 'is' good, surely Premier Pro will use 'some' of the 6870 capability,...?
Can anyone advise? Thank you so much and all the best!... Tom ..
Hi Guys and thanks for the replies.
Well, i wont be upgrading to CS6, only using CS 5.5 for now, so wont be looking at another ATI card..
Can i not use open GL on CS5.5, with my Radeon HD6870?
Maybe my specs might be OK anyway with the current card? I have;
Intel i5 3470 quad core turbo boost
8GB 1600 Corsair Ram
SSD 500MB Read Write
500GB Seagate 7200
How would it perform like that? Would my graphics card 'NOT' work at all with premier pro?
Tom
Your system will simply render with the CPU and you have plenty. Having an ATI/AMD CPU should be of minimal concern.
Have fun!
