Vegas 5.0 MPEG-2 license Registry fix???
Mike
Splendid
Apr 1, 2004
3,865
Archived from groups: rec.video.desktop (More info?)
Back in Vegas 4.0, I remember you could just delete the "key1" entry
under the license section in the registry for Vegas:
How do I do the same fix in Vegas 5.0? Does anyone know?
HKEY_LOCAL_MACHINE\SOFTWARE\Sony Media Software\Vegas\5.0\License is the
Mike
dax702@cox.net
HKEY_LOCAL_MACHINE \ SOFTWARE \ Sony Media Software \ MC MPEG Plug-In \
1.0 \ License \ key1
Doesn't work, but what does work is just installing DVD Architect 2,
even though I don't use it, somehow it registers the MPEG and AC3
components...
>components...
Well, it works for me, even without installing DVD Architect.
Actually, in my registry 'key1' is still there, but it's empty,
both for MPEG-2 and AC3.
Did you first register the MPEG plugin when it asks in Vegas? it says to
register by phone or another computer, u fill in the fields and u put in
the serial number, did you skip that step? Are you using a pirate
version of Vegas?
>>components...
The plugin is registered. If you search for key1 in Sony's Vegas forum
you'll see that the fix still works. Here's one thread:
http://mediasoftware.sonypictures.com/forums/ShowMessage.asp?Forum=4&MessageID=304141
>Are you using a pirate version of Vegas?
Would I admit it if I was? 🙂
