Hello everyone,
Well I consider myself fairly tech savvy and I have recently encountered a problem that has really stumped me and all of my fellow tech buddies. Let me know what you make of the situation:
First off, this problem occurred only after overclocking my Q6600 from 2.4ghz to 3.0, and I know I could probably remedy this problem by underclocking, but I'm trying to avoid that. The overclock has caused absolutely no noticeable problems except for the following. When my computer has been shut down for several minutes and I boot it and the BIOs does not recognize my second SATA drive (a 320gb WD). The drive is not found by Windows at all either. A simple reboot remedies this problem. Other times when the computer has been off, I will power it on and the BIOs will recognize the 2nd drive. Unfortunately, it will NOT be recognized by Windows (vista 64). When the disk is recognized by the BIOs but not Vista the drive shows up in Disk Management strangely enough.
Whether or not the drive shows up in the BIOs seems random, but like I said, a reboot always remedies the problem. Sometimes I will reboot a second time and the drive will disappear again. I've read that formatting the drive may help but there is a load of information on it and I would like to avoid that if there are other options. The most important part of this problem is that I have isolated what causes the drive to disappear occasionally.
I currently have 6GB of DDR2 memory in my rig (4 of patriot, 2 of g-skill). They are both rated at 1066 and supposed to run at 2.1v. When I have them set to 1066mhz in the BIOs, I have this hard drive problem. Setting the memory back to 800 completely gets rid of the issue! I know the performance increase from 800 to 1066 is small, but I would like to get what I paid for. I'm thinking that it may have something to do with my CPU voltage but currently I have it on auto and my motherboard only allows me to increase it by 5,10,15% as opposed to inputting a manual value. Does anyone have any ideas? I'm really stumped.
