I've been reading reviews and checking websites about the GTX 570 and was looking for some advice on upgrading the cooler.
Through my readings, I came across the ARCTIC Accelero S1 VGA Cooler but it doesn't appear to be compatible.
(1) Am I reading all of this correctly that the Accelero S1 Cooler is not compatible with the 570?
(2) If that is correct, does anyone know of a reasonably priced cooler that does a good job and isn't too loud that would be compatible?
I came across the ARCTIC Accelero XTREME Plus II but there aren't that many reviews, it seems a bit expensive, and a little bit like overkill. Amont other things, I'm concerned it may not fit.
Any advice you can give would be much appreciated. Thanks.
The build looks like this currently:
Case: Antec P183
MB: ASUS P8Z68-V PRO
CPU: i7-2600k or i5-2500k
GPU: EVGA SuperClocked GeForce GTX 570
RAM: G.SKILL Ripjaws X Series 8GB 1600
HD: Western Digital Caviar Black 1TB HD
SSD: Crucial M4 128GB SSD
PSU: Antec High Current Gamer Series 750W
OS: Windows 7 Pro 64-bit
Bought a CM 212+ and three Scythe SLIPSTREAM PWM (two to replace the stock fans and one to replace the fan on the CM 212+).
Case: Antec P183
