Hi,
I have a computer that’s been working fine for the past 2 months. It has a Ryzen 3600, Ripjaw 2x8GB 3600 MHz, 2 SSDs, B450 AORUS M, RTX 3070 (GIGABYTE), and a Corsair CV Series CV650. Today, I restarted it and came back 30 minutes later to the computer not displaying anything. I looked at my MOBO and the VGA LED is on. However, when I start up the computer the LED flashes from the CPU to the DRAM to the VGA, then stays on VGA (Not sure if it always does this during start up). When I turn it off, the CPU LED flashes. I reseated the GPU and that didn’t work and also reset CMOS. Nothing is displaying, however, all the LEDs on my MOBO work and my CPU and case fans are running.
Note: The GPUs fans spin initially when starting then stops. I restarted the PC because it was acting sluggish/ buggy when moving files around my computer.
Any tips? My ideas are it's either a fault PSU or MOBO. The PSU is rated 650W bronze.
