Hey, so my VX922 started experiencing this "flashing screen/blinking power LED" a few months ago. For a while I would simply turn it off for a few minutes whenever it changed resolution (I use it as my secondary monitor and have had it for about two and a half years)
I searched around the internet a few months back and read that it was probably the capacitors, but the forum had no step-by-step instructions as this one did. I can't thank you guys enough for the detailed instructions/pictures and even the list of parts!
I proceeded to open up my monitor (taking the back cover off was not fun!) and removed the power board. I could clearly see that about 3 of the capacitors were domed at the top, and one even had a brown spot in the center.
So a few days ago I received the six capacitors (the same ones Gumby listed) from digikey.com and, being completely new to soldering, obtained the help of a friend to assist me in desoldering and resoldering the new capacitors to the board. It all went pretty well, took about 2 hours (desoldering was the hardest part) and I installed the power board back into the monitor. When I powered it on, I was thrilled to find that the monitor no longer suffers from the flashing screen/blinking power LED problems!
However, the monitor is now somewhat dim with what appears to be a faint blinking/pulsating backlight. I tried resoldering a few caps that seemed to have a little too much solder, but to no avail. I checked all the other parts on the pcb boards but found nothing that looked damaged.
It seems as though the backlight is not getting enough power, and this problem has never occurred before I replaced the capacitors. The capacitors all have the correct polarity, all the connections were reattached properly, and the soldering job is as good as a can do. I just find it strange that the problem I set out to correct has been fixed, and everything works like new on the monitor, except the backlight. Also, when I tried adjusting the brightness, it would not increase nor decrease, but the contrast works as it should.
The reason I did not RMA the monitor, despite still being covered under the warranty, is because I have heard poor experiences with ViewSonic's customer service, as well as people receiving different models/less than acceptable replacements. My VX922 is still in flawless shape, so I would rather not exchange it for one with dead pixels/scratches. Also, I enjoy DIY work.
So, If anyone has any suggestions on what might be causing this problem, I'd appreciate hearing from them.
Thanks.
- Mike
