Visual Basic 6.0 on XP SP2 installation problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi,
I have got an error during the installation of VB6.0 enterprise on a system
running XP Home SP2. The error looks like this:
wpie15.exe - entry point not found; the procedure entry point
SetupDiEnumDeviceInterfaces
could not be located in the dynamic link library SETUPAPI.dll.
I have searched the whole day in the web and found that there are others
having the similar problem but are not probably answered. Can any experts in
this forum help ? Thanks.
C Major
Hi,
Resolving problems with the Windows installer:
http://www.rickrogers.org/fixes.htm#Installation
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
"c major" <cmajor@discussions.microsoft.com> wrote in message
news:45F0B268-BAA5-4ED7-A117-8FE4E1394F4A@microsoft.com...
> Hi,
> system
> in
> C Major
I don't think Visual Basic 6 uses the Windows Installer technology. This has something to do with incompatibility of IE 6 I believe.
George Hester
_______________________________
"Rick "Nutcase" Rogers" <rick@mvps.org> wrote in message news:efCMr00aFHA.3132@TK2MSFTNGP09.phx.gbl...
> Hi,
> Best of Luck,
> > Hi,
> > system
> > in
> > C Major
See the suggested workaround described here:-
http://www.mastervb.net/home/ng/forumvbcode.installation/post10437131.asp
regards,
ssg MS-MVP
c major wrote:
> Hi,
> C Major
Thanks,
I have read the workaround. It seems applicable and I'll have a try later
today. But copying the whole CD really takes some time.
C Major.
> regards,
> ssg MS-MVP
> c major wrote:
> > Hi,
> > C Major
Hi,
I have tried it. It installed without a single error message. But it
crashed when I start VB everytime. Really bad!! I think I have spend to
much time on this installation problem and I must give up and switch to my
old win98 which works so good with VB6. But thanks anyway to you guys.
C Major
> regards,
> ssg MS-MVP
> c major wrote:
> > Hi,
> > C Major
