I overclocked my e8400 to 3.6 ghz after installing my new glacial tech f101 heatsink and HAF 932 case. I set the voltage to 1.325 I believe, do you think that's a bit too low or high, when I got it around 1.38, my system made whining noises and froze a lot.
I've run the CPU through the gauntlet that is crysis on max settings for an hour then I played COD MW2 for like 4 hours and it seemed fine.
(side note: got a huge increase in FPS from doing this)
I want to ramp it up to around 4ghz later on and I am also wondering if that voltage would be safe for that, I know this sounds petty but I don't really like messing around with voltages, I have a bad taste in my mouth from my first ever OC a few months ago where I got the blue screen of death and a memory dump.
