Hey people just looking for some suggestions as to how to go about upgrading my htpc so it could be used for slight to moderate gaming.
http://reviews.cnet.com/desktops/acer-aspire-x1200-u1520a/4507-3118_7-33229227.html?tag=mncolBtm;rnav
Thats the HTPC I have in the guest room where my cousin will be staying at for a couple of months and would like to upgrade the power supply and video card.
Problem is im not exactly sure what power supply to use. It is a small factor case so Id need a specific kind of power supply.
Id also need a low profile video card but im not sure what the best one would be to get. I have a budget of 150 bucks to spend on the video card and max 80 bucks on the power supply and would like some suggestions on what to get. I want it to run black ops on at least medium settings minimum(high would be awesome) on a resolution of 1024x720(sometimes 1920x1020). Would like suggestions on what to get. Im also not sure how the processor would fare nowadays and if it will bottleneck the video card but i doubt it will be an issue.
As Im typing this i been looking around the net and found the Palit GTS 450 low profile card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261078&Tpk=Palit%20GTS%20450
I was also thinking about just getting this power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371023
and leaving it outside the case resting on the side on top of a little stand i have right next to the htpc at the same level making sure no vents are blocked. Would that work too? I dont care about how it looks or anything but i just figure itll be cheaper and will generate less heat than having it inside the case.
Any input would be really appreciated.
