This happened after I install the new Nvidia driver - version 496.13, the display shifted to a greyish colour and everything seems transparent. The monitor then went to sleep mode
I tried to reinstall my GPU driver and changed my DisplayPort cable but nothing works.
When I perform a clean driver install, It will change back to the normal colour for a few seconds and the monitor will go to sleep mode itself. The monitor will not wake up from sleep mode afterwards.
I tried to roll back the driver in device manager, and the colour on the monitor reverted back to normal.
Then I tried to reinstall the driver again and without surprise, the screen turns back to this greyish colour.
I tried both 472.12 and 496.13. Both didn't work.
I first downloaded the driver through Geforce Experience, which is the latest version.
After the incident, I uninstalled the driver using Display Driver Uninstaller.
I then reinstall the older driver 472.12 via NVcleanstall. Didn't work. Tried the latest version again, didn't work.
I also tried using Geforce Experience again, same result.
Spec:
CPU - 5 5600X
GPU - RTX 2060
RAM - 32 GB
Mobo - B550 Aorus Elite v2
SSD - Samsung 970 EVO Plus 500 GB
OS - Windows 10 pro x64
Spec:
CPU - 5 5600X
GPU - RTX 2060
RAM - 32 GB
