Wat size power supply
mopkop
49
Im currently building a pc
i7 2600k
ASUS P8P67 Pro
2x GTX570
2x 4gb Corsair dominators
2tb hdd and maybe 32gb sdd
just need a more or less size power supply that you guys think would be strong enough
As Davcon says, the Corsair HX-850 is modular and will work great for you. I have this PSU and I am very satisfied with it. Same with the Dominator RAM.
The height of the Dominator RAM is 52 mm (2") and this could present problems in slot 1 of the RAM as far as certain heatsinks are concerned. Check this aspect out.
