Question Water cooling 6800 xt
Feb 9, 2023
6
Hello guys,
I have a question about my 6800xt. I have a 6800xt asus tuf edition and online i found an aio for an 6800xt.
The problem is that the block i found online (alphacool eiswolf 2 aio) is for a reference 6800xt.
So my question is: is the pcb on the asus tuf and the refrence card the same? or where can i find this information?
thx for helping me out here!
Thank you so much man, but there is no aio? (i do not like a custom loop... hahah)
Oh, alphacool also sells that, but I wouldn't really call that an AIO, more of a pre-filled custom loop with quick disconnects.
https://www.aquatuning.us/water-coo...adeon-rx-6800/6800xt-strix/tuf-with-backplate
For that much money, you are better off doing custom. That way you can more easily recycle the parts later on. Future investment type thing.
For example, I also use an Alphacool AIO type product, but it is just a pump/res/rad combo, that I can re-use for anything with standard fittings.
Alphacool Eisbaer Extreme Core:
https://www.aquatuning.us/water-coo...-extreme-liquid-cooler-core-280-black-edition
Plus GPU block, 4 fittings, and some tubing and you are all set.
