I am thinking about investing in a water cooler for one specific reason. That reason is to reduce the amount of heat in my computer room. At first I thought that this might be the perfect solution but now I have my doubts. At around 200 dollars for this investment I figured I better find out if my theory is right before I spend the money. Do water cooling units reduce the amount of heat that is released into the room? I am starting to think that the answer is no. The heat must go somewhere is my theory now. Even thought the heat may or may not be more effeciently removed from the process that heat must go somewhere right? Tell me I am wrong and the water cooler disapates the heat and the computer is at best room temp. If anyone has a water cool I would be very interested in your experiences with them. Do your computer rooms still get hot? I suspect that your computers are much cooler but since I am not into over clocking I could care less if my computer runs any cooler then it is now. The current fan set up I have now does a good enough job of that. My goal is to reduce the temp in the room and if a water cooler will help then I will make the investment. Thanks for anyones thoughts on the subject.
