[SOLVED] Water cooling question.
which zotac 2080ti? need the model to tell if the gpu block is compatible or not.
alternatively, a list of compatible 2080ti : https://www.ekwb.com/configurator/waterblock/3831109810477
the air 740 can take a 360 rad in the front and a 240 in the top. the max gpu clearance is 330mm.
so i would suggest this for the top rad : https://www.amazon.com/dp/B0067LW8RY/ref=twister_B07BDQ178P?_encoding=UTF8&psc=1
and this one for the front : https://www.amazon.com/XSPC-EX360-Radiator-Triple-Multiport/dp/B008BWR0SY/ref=sr_1_21?s=electronics&ie=UTF8&qid=1546277926&sr=1-21&keywords=360mm+radiator
pump res combo would have to be placed in the backside of the case, yeah i know, wont be visible, cuz u got no space in the front. i would suggest...
pump res combo would have to be placed in the backside of the case, yeah i know, wont be visible, cuz u got no space in the front. i would suggest this pwm pump res combo : https://www.amazon.com/XSPC-Special-Photon-Reservoir-Aluminum-x/dp/B071KZ9RLS/ref=sr_1_18?ie=UTF8&qid=1546278773&sr=8-18&keywords=pump+reservoir+combo
u have already bought the xi code? cuz the hero got an ek monoblock. the formula got inbuilt vrm waterblocks. but the code doesnt have any monoblock compatibility. so that leaves an ek vector cpu block? i would suggest the phanteks cpu block : https://www.amazon.com/Phanteks-PH-C350I_BK-Solid-SKU-Mounting-Bracket/dp/B06WRV3DCL/ref=sr_1_4?ie=UTF8&qid=1546279157&sr=8-4&keywords=intel+cpu+block
tubings and fittings, i leave it to you. http://www.tomshardware.com/forum/277130-29-read-first-watercooling-sticky#3718885
Latest posts
