I'm looking into water cooling, it is quite warm in my room
I was thinking I use a Danger Den - TDX Block and a Black Ice Micro II Radiator.
I'm not sure about which pump to use. I suppose this is very important since I wouldn't want it to fail, but I also don't want it to be too loud or takeup too much space. I've seen some relay switches I can use so it turns on with my computer, are these reliable?
the other question I have is if it is necessary to have a resevoir. don't these just keep more heat in the box?
I plan to setup all this internally.
I'm also unsure about the fittings wand which size to use. Is there a nice article about this?
I've and browsed a few other sites, so I think I got the basic idea, but there are still many specifics I am not sure about.
Any suggestions?
Any suggestions?
Personally I wouldn't build a watercooling system without one, but that doesn't mean that you have to. One can certainly be built without.
