I have an alienware pc, so I don’t know what brand of hard drive it is, but is has been making a strange clicking sound lately. Just wanted to know if this was normal.
View: https://youtu.be/EbjEfNref7E
yes I have checked for things in the fans. I didn’t find anything. I am pretty sure it only happens on idle now after ignoring it for a bit. I will try the gpu software.Did you check if something is in the fan blades? Try a fan controlling program and reduce the speed of your GPU fan and see if the noise slows down. SpeedFan is what I use http://www.almico.com/speedfan.php.
I cant use that software to stop my gpu fan.Did you check if something is in the fan blades? Try a fan controlling program and reduce the speed of your GPU fan and see if the noise slows down. SpeedFan is what I use http://www.almico.com/speedfan.php.
I was sure that this program could control the gpu fans. If ever you want to control the fans there is always this program but be careful not to play with the overclocking settings!I cant use that software to stop my gpu fan.
