[SOLVED] Weird PSU noise
KevinFD9
CPU : Ryzen 3100
GPU : MSI GTX 1660 Super
Motherboard : Gigabyte B450M DS3H V2
RAM : 16GB 3600 (2x8GB )
PSU : Corsair TX650M Gold
So, I recently built my PC and started to notice there's a weird zapping/arcing like noise coming from the power supply. It doesn't seem like to increase or decrease under load or when idling and sometimes it gets louder or quieter without any apparent cause. PC continues to work flawlessly and doesn't seem to be affected by it. It only starts to make this noise at random times and sometimes it goes away on it's own or It will keep making the noise until I turn the power off at the wall. Should I be concerned about this?
Thank you.
View: https://soundcloud.com/user-425043282/psu-noise
CPU : Ryzen 3100
Thank you.
View...
CPU : Ryzen 3100
Thank you.
Yes you should be concerned. I'd pull it out of service now if I was you before it damages your PC or worse...arcing noises are never good in a PSU.
Reactions: KevinFD9
