Question Weird sound coming from cpu or gpu.
Lutfij
Sounds like the VRM area of the motherboard, but it's an assumption with what limited info you've provided. Roll up a sheet of A4 paper into a cylinder, then hold one end to your ear while the other end is used to probe for the source of the noise.
We're also going to need your system specs. Please list them like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
triplex1
814
129
570
Hi. I heard a strange buzzing/beeping sound that I can't really explain it. I attach a link with the sound. I opened the pc's backplate and it seems to be heard from the processor area. I only hear it when I have the pc ul on idle, the sound disappears when I'm playing. What is it coming from? Is it normal?
View: https://youtube.com/shorts/r0kht28gy1E?si=2TUO3PG2E-qWsJyy
what power supply do you have in the system?
Psu-Mb-Cpu and Gpu
Vlad951
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
I5 12600kf
1st player mothra mt240
Aorus b760 elite ax ddr4
32gb ram
2tb ssd
Rtx 4060 ti msi ventus 3x
Corsair cv650 (1year)
Windows 11
I don t know exactly the bios version.
The sound is coming from the cpu area
triplex1
814
129
570
Many watts in processor, graphics card ++, for the specific power supply, which is bronze and is not one of Corsair's best.After a year of operation (and you certainly play games, it probably needs a change)
*** Put your ear to the water cooling pump, there is a chance that it will make noise
triplex1
814
129
570
Thx for the answers. Anyway should I be worried about this sound or it s ok ? Can it do any damage ?
As I told you before, you will have to check.If the sound is from the water pump (I say this because you said it comes from the processor), you can do a test with an air cooler.
If it is from the power supply (for which the currents it sends may not be enough and the water pump also makes noise) you can remove devices that require power such as hard disks that you have for storage and anything else leaving the basics such as the keyboard and the mouse.
It's easy to find out what's wrong that way
triplex1
814
129
570
If it is from the power supply, at some point it can take the motherboard with it and it in turn can take the graphics card with the memories.
So you'll have to look at it.
Its water pump is just as serious
