Question what configuration of parts should i go for
Aug 27, 2019
9
AMD3600, x570 MB and a RX580 = £526
or
AMD 2600x, B450 MB and a 1660ti = £495
I am thinking the top as it gives me better futureproofing (I think)
any thoughts
cheers
COLGeek
Cybernaut
I would go with option 1. The X570 chipset provides more performance potential and greater compatibility for future upgrades. The RX580 is no slouch at 1080p gaming, either. The Ryzen 3600 is an excellent performer as well. I believe the price difference is warranted for the gains achieved.
What memory do you intend to use?
As far as future proofing.....the top one.
As far as how it's going to perform on games now.....the bottom one.
Although if you are only gaming at 1080p I don't think you will get much more out of the 1660 Ti than the RX580 at 1080p @ 60 fps.
Reactions: Pryce11
Aug 27, 2019
9
16gb 2x8 3000
cheers, I think I will go for the top
Aug 27, 2019
9
yep will be 1080P
plan to save for a better graphics card and monitor for a few years down the line.
Aug 27, 2019
9
Then I would go for the top one.
Think I knew that deep down! just needed validation, been going over different setups for weeks, been tearing my hair out over it as its a big expense, best to ask and get right!
guessing what I have read is true and that MSIs are the better Mobos to go for or does it really matter.
Cheers again
9
"or does it really matter. "
I think that some manufacturers are better than others.
I try and go with ASUS as I've had great luck with them.
also is what I have read about the 3600 not working brilliantly on a B450 true or is it exaggerated?
why I have gone off the idea and gone for the more expensive x570
sorry for pestering !
cheers
g-unit1111
cheers
Because if you use a current generation CPU on a previous generation motherboard, you will require some way to update the BIOS (which usually means previous gen CPU) before you can use the new chip on it. It's usually better to get current generation hardware including motherboard so you don't have that hassle out of the box.
