Hi,
I'll write my question in details and will summarize at the end:
I have AMD FX 8350 and motherboard Asus M5A97 EVO R2.0.
I had problems with it's high temp when I was using stock fan, when the usage was 70%-100% the temp used to go up to 69°.
Early May 2020 I installed Dark Freezer X94RD fan. The maximum temprateure I saw was some 54°, I was happy with that and stopped monitoring the CPU's temp.
BUT, few days ago, I was play a game that uses some 90% of the CPU most of the time and the PC just turned off while I was playing. I immediately suspected the CPU's temp, which actually was extremely high.
I cleansed the dust, removed the new fan, removed the old theral paste and put a new one, but the problem was not solved.
the CPU's temp can now goes up to 57° in Bios, on Idle state it's between 39-45° and in games it can go as high as 74° ! this is insane !!
I tried almost every thing, I cleansed the case from dust, I put new paste with enough quantity, the fan is firmly installed, and updated the Bios.
what could possible be the problem. I just don't get it?
I live in Istanbul and the weather is kind of hot (some 29° with high humidity), but there is no way that could be an enough reason for the CPU's temp to reach 75° or more !
I even tried to leave the case open and put a small (normal) fan facing it, the max temp went down to some 69° which is still high.
what I noticed is that the temp doesn't go down as quickly as to goes up, could that mean something?
I also noticed that if the CPU's temp goes high and I touch the fan's aluminum it also feels that, doesn't that mean the conductivity is fine?
one more notification; recently and out of curiosity I touched the motherboard's blue metal of "dual intelligent processors 3" when the CPU was at 43°, it was super hot, is that normal?
Summary:
What did I miss? how do I fix the CPU's temp problem?
Thanks in advance,
Summary:
- AMD FX 8350 CPU + Dark Freezer X94RD fan = CPU temp extremely high (only noticed recently).
- Bios is Updated.
- Thermal Pasted is renewed.
- Dust is cleansed.
- Weather is kind of hot.
- Fan seems firms, and heats up with CPU, which should indicate high conductivity (I guess).
- Opening the case and puting a normal fan facing off the CPU's fan only seems to decrease the temp a little bit, but doesn't solve the problem.
- CPU's temp goes high quickly and cools down slowly.
- Aluminum of the motherboard's dual intelligent processors 3 is very hot.
Thanks in advance,
