maxalge :
mp8802 :
I bought GTA 5 for PC and it said I don't have enough video memory. I never had that happen to me before (I forgot to read the specs). The one I have now is a Radeon HD 4550 (I think it's 512 mb). Anyway, need something top of the line please and asap!
you are not going to get anything even close to top of the line without major rebuild
the best you are going to get to run on that is a low profile gtx 750 ti ( depending on your power supply wattage )
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836
The 1st one, "N750 TI TF 2GD5 OC" says gaming and it's 400w.
the 2nd one is a little cheaper and is 450w. I'm not sure what the difference is other than that.
This is my power supply according to my model search (I didn't actually take my computer apart and look). It seems to be 240 w by default. Are you saying I need to get a new one to have a gaming graphics card?
http://www.newegg.com/Product/Product.aspx?Item=9SIA3AN39B6898&cm_re=hp_compaq_6000_pro_sff-_-9SIA3AN39B6898-_-Product
