What Is The Maximum Temperature Stock Fan Core i7 920???
The faster you OC it and the more volts you supply, the hotter it will get, so there's not really a "maximum" of how hot it can get (until it physically starts failing, of course). The Intel datasheet for the specific CPU you're interested in will list the maximum "safe" temp.
I think the question is, what is the temperature of an i7 920 at stock speed and voltage under full load with a stock HSF? Intel defined some criteria for the minimum performance for a heatsink. What do they consider a maximum healthy temperature?
It's a rhetorical question. Unless someone has an answer of course.
Depends on ambient(room) temp, but mine is at stock around high 30's, low 40's. Loads are 50's-mid 60's, topped out at 71.
Hi scrumhalf, I just wondered. What do yo think about my i7 temperatures? I have a i7 with Noctua 1366 SE cooler,
MB is around 50C
CPU core temp around 56-57 idle
GPU (GTX 260 asus TOP) around 50 C
Everything is idle and i just think that these temps are a bit too high?? should i not worry? I admint, that is have used the SILENT mode for fans in hte BIOS, but they are running at around 800 RPM, and CPU-fan ~1100 and GPU -fan around 1300 rpm.
My problem, is that i did not see any real improvement from the stock cooler to this one..
Regards ,Frodi (copenhagen)
How about you explain your reason for asking this question. We can better answer you then. There is no SET max. Actually I believe it is 115C but you will NEVER want to even come close to that.
So I have less than a week that I took my new set with:
Intel I7 - 920 (stock heatsink)
Kingston DDR3 2048 x 3 1333Mhz (KVR1333D3N9/2G)
Asus P6T WS Pro
etc on a cooler master chase.
The room's temperatures are around 25C to 26C and humidity at 80% (aouch I know).
I hadn't stretched the CPU at all till today cause the maximum I could get out of it was about 26% while brute forcing and installing programs simultaneously and was very happy with the speed. However I badly wanted to see loading at 100%. Got real temps that I've heard that works good on it and prime 95 for the cooling down temp. But the results...... :S
Are these temperatures close to normal? :S I have installed the stock heat sink very carefully with the pre-installed thermal paste on it (well my finger took a little) and now?
(Oh I have the chase open and one 120mm fan behind at full rpm)
I have the serious and very bad feeling that it is not a heatsink problem because while the temperatures rose I could (barely but indeed) feel a small increase on the heatsink temps...
That's high. You see at 97.7% load there is 6 degrees left to TJMax for two of the cores? TJMax is where the CPU will shut down from overheating.
I think you should have had more margin than that, even with the stock cooler and 26 degrees room temperature. (I'm getting ~20 degrees to TJMax at 22 C room with an aftermarket cooler. I think core temps scale approximately linearly with ambient temperature, so you would have had maybe 10-15 C left.)
But I also think you are still safe, at least as long as you didn't turn off thermal management in BIOS. It's not too hot as long as you have a little margin to TJMax left, and as long as the "thermal status" i Real Temp is OK. (It will show a notice if the CPU is or has been too hot, check out the Real Temp documentation.)
Here are a couple of links for you:
"unclewebb" in this link is the guy that makes the Real Temp software. He thinks
the i7 stock cooler is "barely adequate" and recommends buying an aftermarket cooler.
The person posting his temps on the i7 runs even hotter than you. If that's a comfort :)
A Legit review here says that most aftermarket coolers shave 10 C or more off the Intel stock cooler temps under load. (Although I have heard others say they got very little difference.)
Not sure if the Real Temp sensor test is long enough to warm the heatsink. But if you run Prime95 for 10-15 minutes and have coretemps 80+ degrees, the heatsink should be uncomfortably hot to the touch. If it isn't, it suggests the processor doesn't transfer heat to the heatsink as it should, and you should try reseating it. (You will need new thermal paste.)
Good luck :)
Hi Frodi,
What is your pc case your using? Make sure u have good ventilation in your system. Not enough ventilation may result in higher temp. How many fans does your pc has? if 2 only try adding 2 fans more.
Marion
Hi Frodi,
Your idle temps are high. If you have plans to OC your system I would install the Corsair H50. It is not too expensive but you get a massive difference in cooling. I am running the Core i7 920 at 4Ghz with my CPU cooler being the Corsair H50 and my system on max load. Prime95 does not exceed 68C. If you are sitting idle at close to 60C you could run into temp issues when you OC.
Dean
Hi,
I'm running stock cooler and prime 95 max temps hit 75C for me (on max cpu fan speed). I have the P6TDeluxe and have a GTX 260.
To keep my system quiet I run the stock cooler at 63% (when not running prime 95) speed and idle temps are 40C for CPU and 41C for MB.
I do find that with the GTX 260 being so close to the north bridge I think it's poluting the temps, because in Prime 95 CPU hits 75C and MB hits 43C.
when I'm in a 3d game max CPU hits 55C and MB also gets to about 55-56C.
Any thoughts? I considered moving the video card to the bottom PCI express slot to keep it away from the north bridge, but I foundit difficult to connect the wires for the power, was getting in the way of the indake fan of the video card. I may try that again and compare temps.
Anthony
I've just put together a system with liquid cooling for the first time and I have a small overclock on it courtesy of the EasyTune6 app. I just tried the Prime95 program and I saw my core temps rise from around 47-50 at idle into the mid 60's. I was called away and the last I saw they were at 66-67 degrees and when I came back about 20 minutes later the pc was sitting at the login screen having crashed (first time this system has crashed in the 3 days it has existed). Should I be expecting better cooling than this from a liquid cooled system or am I expecting too much? I bought this kit with the intention of shooting for a 4Ghz overclock as pretty much everyone online seems to be reporting this as dead easy with this gear.
Windows 7 Ultimate (32 bit)
Intel i7 920 (D0) @3.2Ghz
Gigabyte EX58-Extreme
OCZ Reaper 6Gb 1866
ThermalTake Kandalf LCS case (built in liquid cooling system)
Any thougts?
Cheers!
Vormulac ,
Welcome aboard! Please read the Stickies, and use SEARCH ... you can't miss it ... top dead center of whatever page you're on.
Guys,
This thread is a thermal train wreck, and a FUD-Festival! :ouch: Newcomers have been dredging this up almost on a monthly basis since it was originally posted on January 9th! I'm too busy to watch the Forums like a hawk for a few days, and this damned thing pops up ... again?
Enough! Let's get this mess cleaned up and into perspective. I'm once again posting the following for everyone's benefit, so here's what you need to know. Please, read and heed:
If you'd like to learn more about processor temperatures, then just click on the link in my signature.
Hope this helps,
Comp :sol:
You say there is a 5 degree spread? Then why do I get a 18 degree like spread? My cpu temp is like 20 degrees while my cores are bewteen 32-38 degrees...
Thanks.
Read my post above once again ... this time a bit more carefully please.
I'm sorry I must have been speed reading. I have the Evga Classified and must be a nuance associated with the kind of board or the cooling system used? Its water cooled. The gap I think gets closer after it warms up a bit, but its always like a 12 degree difference where the cpu temp is like 20 degrees and the core is about 32.
On my Abit 680i board the two temps are almost identical with the core temp being a few degrees colder than the cpu temp. That one has a TRUE installed on it...
Anyhow, thank you. I will try to read more carefully from now on,
Dave.
Prime95 torture test "blend", temps are hovering at CPU 66c, and system 27c during a 20 minutes run.
i7 860 w/ Stock Heatsink
4gb ddr3 G.Skill 1600
Biostar T5XE CFX SLI
Idle temps are CPU 19c, and system 23c
Does that sound about right?
edit: just downloaded Realtemp on a suggestion. I think the other temp monitor might have been off a bit by about 12+c. Did not do a full stress test yet though. So maybe I was in the lower to mid 70s in the testing I mention above.
~70x is optimal high. CPUs are rated for around 80-85c max, but no never want to be up there. Also, they'll throttle themselves down if they get too hot.
Anyone remember the video of someone removed the heatsink off of the P4 while Quake3 was running and the game about stopped. Then they put the heatsink back on and the game sped right back up to normal.
The AMD cpu at the time didn't fair so well as it surpassed 200c instead of slowing it self.
CompuTronix I understand your info seems to have come from a reliable source but to me it seems inaccurate. I'd welcome correcting if I'm wrong but my understanding is as follows. Real Temp measures the distance from TJMax NOT the actual temp of TJ. Now my PC will idle about 66degrees below TJMax and if I set TJmax to 73 as you suggest real temp says my TJ is about 7degrees. Now while I'd love this I can't believe its true...
Leaving TJmax at 100 degrees means my idle is around 34 degrees (which for a 920 OC'd to 4Ghz on air seems more accurate)
There seems to be a huge variety of info on this subject some of which seems good, but some is clearly wrong. Max temps I'd take with a pinch of salt. Different CPU will generate different temps and have different Max temps. The only sure rule is the lower the better!
As a point of reference I'm running a 920 at 4Ghz with a core Voltage of 1.328. This is on a Gigabyte UD5 Mobo with a Prolimatech Megahalems cooler with 2 Scythe Ultra Kaze 2000RPM fans. (This is in a large, well vetilated case)
I get an idle between 33 and 36 and a max of 72 on my hottest core after around an hour of Prime 95. Under normal use or gaming my CPU has never touched 50.
Sorry hit post too quickly with a typo in. Last bit should be "Under normal use or gaming my CPU has never touched 60" not 50.
I have mine OC'd to 3.48GHz @ 1.325V and in Prime 95 it won't exceed 64 C. Not oC'd it won't exceed like 55C or so. I'm using a XIGMATEK Dark Knight 120mm CPU Fan.
