[SOLVED] what is the problem with ryzen 2600?
Noothan
54
my pc configuration :
psu cooler master 550watts
mobo - asus ex a320m
cpu - ryzen 2600
ram- 16gb ram 2400mhz(3000 oc)
graphics - gtx 1060 6gb
i bought the processor around 2-3 months ago and when it was new, it was very speed and boot was fast and i din have to load if i open any app like say google chrome, and the cpu usage would b 2-5% in idle ranging 1.5 ghz - 2 ghz and stable
now after 2 months of use, the cpu seems fishy it keeps going for 3.4-3.6 ghz even when idle and it loads for 5 secs when i try google chrome and similar small apps, this is still same even after reseting the pc and removing everything cleaning, the cpu doesnt seem stable, its fast varying from 3.4-3.6 ghz as i said, and there are no background apps running as everything removed or no windows update. or no start up apps, and even bios is upto date, and benchmarks are fine, its just slowed down and am sure something is wrong with cpu, what to do., anyway to check and sort?
