![Vendredi :vendredi: :vendredi:](/data/assets/smilies/vendredi.gif)
Which motherboard will be the best to go with in this situation?
And also, here's the build that I was talking about: https://pcpartpicker.com/list/hgqsy4
Alright, so I've done some research and I've found out that the Fractal Design Meshify-C is one, if not the best case.Welcome to the forums, newcomer!
IMHO, for your good, ditch the idea of getting the NZXT H510 Elite case, since it's horrible in terms of thermals/performance. Sure it looks nice but the aesthetics are what chokes the fans and in turn make the innards more of an oven than an airflow arena.
As for your build, why are you looking at an 8th Gen Intel platform as opposed to something more concurrent? The motherboard for the processor is also off, if you're adamant on getting the 8th Gen i7 k suffix processor, you should be looking at a Z390 chipset otherwise that processor will not be possible for overclocking, and the ram will be limited to DDR4-2666MHz. Finally, yes that board doesn't have a USB 3.2 Gen 2 header on it since a bottom of the barrel board will have no need for that connector. People on a budget like that would bother with Type-A ports only, not type-C front panel ports.
Taken into consideration, I've modified the list to include the new PSU, but one slight issue.Hopefully you buy 8700K and Z390 second hand? It's not worth to pay $375 for a 4 generations old CPU. 12600K is cheaper and performs about 50% better. Z690 motherboards are more expensive but overall you get a lot better performance for $25 extra. Z690 supports USB-C and USB3.2.
Cheaper and slightly better PSU https://pcpartpicker.com/product/qH...fully-modular-atx-power-supply-220-g6-0750-x1
Why do you hold on that motherboard?The 12600K you recommended me to use does not work with the ASRock Z390
Honestly it's not a good purchase. https://pcpartpicker.com/product/92VmP6/intel-core-i5-11400-26-ghz-6-core-processor-bx8070811400 performs better and is a lot cheaper. More modern also with PCI-e4.0.nd I'm honestly leaning more into the 8700K rather than that.
I want to hold on to the motherboard because it's very good for it's price, as I can't really find anything that's good to use with the Intel Core i7.Why do you hold on that motherboard?
The i7-8700K isn't.I want to hold on to the motherboard because it's very good for it's price
Why hold on to an old and very expensive i7? i7-8700K is worth less than $200!as I can't really find anything that's good to use with the Intel Core i7.
I did not suggest a crappy B360 motherboard.I've changed the list to include the new part you have suggested: https://pcpartpicker.com/user/xirzy/saved/PzPPFT
Only just clicked the link, he using a crappy B560 motherboard with an 11400.I did not suggest a crappy B360 motherboard.
