What power supply should I get?
David_166
71
Hi I'm looking to buy a high end PC build and I'm wondering what the recommended power supply should be for the following:
ASUS STRIX B250F GAMING Motherboard
Intel Core i7-7700K 4.2 GHz QuadCore
ASUS STRIX-GTX1070 8GB
HyperX FURY 8 GB (2 x 4 GB)
x3 Case Fans (Not sure what model they are)
Noctua NH-D9L
Note: I'm not looking to overclock the I7 nor the 1070 only in the future maybe/
If you don't want to overclock on the platform then why did you pick up the i7-7700K? I understand the logic behind the B250F board but getting a non K suffix i7 would be worth while. On the topic of worth while, you didn't mention the frequency for your ram. Since you're on the B250 chipset, any ram frequency above 2133MHz is effectively not recognized/is usable. No matter how high of a kit, the platform will only see your rams running at 2133MHz.
You would need a PSU of at least 550W from a reputable brand of a good quality(preferably Tier 1).
Might it be possible to pass on your location and a budget for he entire build+the amount reserved for the PSU purchase?
The Frequency of the ram card is 2133MHz, I also dont mind spending an extra £30 getting an unlocked CPU as I said I'll be thinking of overclocking it in the future or sometime soon. My Budget is around £1000 however I've already got an SSD and an NZXT S340 case I live in scotland so getting parts from amazon is no problem.
Please tell me If theres anything else I need to change as I'm still an amateur at building pc's.
