Hello people, I have an old system with a bad Power Supply unit, the PC tends to restart or shut down from nowhere and sometimes we need to unplug and plug the power cable in order to make it work again, the labels are old so I don't know what wattage was that old one, the system is this:
CPU: Core i5 650
MOBO: H55 Gigabyte
VIDEO: GTX 460
FANS: 1-120mm, 1-180mm
PCIE: TV Adapter
STORAGE: 1 HDD & 1SSD
I was thinking about using a 500w in case of some upgrades one or you would recommend another one?
Also, should I use a certified one 80 plus White or Bronze or a non-certified one should be ok?
Thanks in advance!
CPU: Core i5 650
MOBO: H55 Gigabyte
VIDEO: GTX 460
PCIE: TV Adapter
Thanks in advance!
