Solution lmaonade200 Jan 30, 2014 well 3.8 inches is about 100mm, so it's either a 100mm case fan or the standard sized 120mm
lmaonade200 Distinguished Oct 31, 2013 1,134 0 20,460 Jan 30, 2014 Solution #2 well 3.8 inches is about 100mm, so it's either a 100mm case fan or the standard sized 120mm Upvote 0 Downvote Solution
bgunner Judicious Feb 13, 2009 5,153 26 32,540 Jan 30, 2014 #3 120mm fan is what you will need to purchase. Upvote 0 Downvote
