Question What to choose ( Legion, ROG strix, or Victus) HELP
Ammar_Howeka
7
Hey guys,
I want to buy a new gaming laptop for (3d Rendering, engineering projects, and GAMING)
I've 3 laptops in mind and need ur help.
Legion pro 5i = 1500$
  • Intel® Core i9-13900HX + RTX 4070 Laptop GPU (8 GB)
  • 32 GB DDR5-5600 MHz RAM
  • 16" diagonal, QHD (2560 x 1440), 240Hz, 3 ms response time, IPS, Anti-Glare / Matte, Low Blue Light, 500 nits
  • 4-Cell: 80 Wh
ROG Strix G16 2023 = 1760$
  • Intel® Core i9-14900HX + RTX 4060 Laptop GPU (8 GB)
  • 16" diagonal, QHD (2560 x 1440), 240Hz, 3 ms response time, IPS, Anti-Glare / Matte, , 500 nits
  • 4-Cell: 90Wh
Victus 16 = 1600$
  • Intel® Core™ i7-13700H + RTX 4060 Laptop GPU (8 GB)
  • 32 GB DDR5-5200 MHz RAM
  • 16.1" diagonal, QHD (2560 x 1440), 165 Hz, 3 ms response time, IPS, micro-edge, anti-glare, Low Blue Light, 300 nits
  • 6-cell, 83 Wh Li-ion polymer
PLEASE I need ur help! the best in cooling system is ROG STRIX, while has no ability to beat the others in GPU.
Legion is the best price but LOWEST Battery.
Victus is in the middle! but 165hz fresh rate!!
Can you help me to choose among these laptops?
Not going to be seeing 240 FPS at QHD with a 4060 or 4070 unless you are playing very light or older titles.
Battery size shouldn't be that big a deal, when using the GPU or stressing the CPU, it pretty much needs to be plugged in anyway.
AMD CPU alternative 7840HS and 7940HS and 8845HS and 8945HS are quite comparable if you want to shop around.
https://www.newegg.com/p/1TS-000E-19SR2?Item=9SIAMRPK4M4848
Reactions: Ammar_Howeka
Ooh man thank u i thought ill get no answer.
So what is ur opinion?
Ive benchmarked the ryzen and it was a disaster against the intel! I need a laptop of them which os designed for heavy duty 😫 if i increased the legion to 4080 would be there any difference or just waste of money?
