Hello, I've been having problem recently with restarting pc, when i do it with case button it works fine, but when i do it with windows option it starts restarting but it doesnt turn back on while the LED's in pc are still on, pressing power button instantly shuts it down and when trying to turn it on LED's on components blink for a second fans start spinning for a second and then they stop, after few times of pressing power button it will actually start but it will be same as restarting black screen but components are on, only fix is as per usual pulling out power cable and plugging it back in and only after few seconds you can actually press power button to start it.
I tried reseting cmos battery, updating bios, cleaning everything, changing thermal paste, testing PSU and GPU, changing RAM sockets, checking for anything loose etc... Basically everything you can find on Net.
My pc specs are:
Gtx 1070 Gainward
Kingston Ram 16gb
Cpu Ryzen 5 1600
Motherboard b450 Aorus Elite
PSU Cooler Master 600W
If you need any additional info just ask, thanks in advance.
My pc specs are:
Gtx 1070 Gainward
Kingston Ram 16gb
Cpu Ryzen 5 1600
