Whats the best components i can purchase for my EPoX EP-8RDA3+ PRO Motherboard?
The_Bill88
20
Hey iv dug out my old PC from a few years ago, it's now my only PC and i need it badly for some 3D animation college classes im taking. So anyway I need to upgrade it as much as possible. So what my question is, is what are the very best/fastest components, such as CPU, Video Card, what type of RAM that are compatible with this motherboard, and any other parts you might think could be upgraded.
Here are the motherboard specs.
Model EPoX EP-8RDA3 PRO 462(A) NVIDIA nForce2 Ultra 400 ATX AMD Motherboard
Brand EPoX
Model EP-8RDA3 PRO
Supported CPU
CPU Socket Type 462(A)
CPU Type Athlon XP / Athlon / Duron
FSB 400/333MHz
Chipsets
North Bridge NVIDIA nForce2 Ultra 400
South Bridge NVIDIA nForce2 MCP
Memory
Number of Memory Slots 3×184pin
Memory Standard DDR 400
Maximum Memory Supported 3GB
Channel Supported Dual Channel
Expansion Slots
AGP Slots 1 x AGP 4X / 8X
PCI Slots 6
Storage Devices
PATA 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s 2
Onboard Video
Onboard Video Chipset None
Onboard Audio
Audio Chipset Realtek ALC85x
Audio Channels 8 Channels
Onboard LAN
LAN Chipset Cicada CIS8201
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 2
COM 1
LPT 1
USB 1.1/2.0 4 x USB 2.0
S/PDIF Out 1 x Optical, 1 x Coaxial
Audio Ports 6 Ports
Onboard USB
Onboard USB 4 x USB 2.0 connectors support 4 ports
Onboard 1394
Onboard 1394 2 x 1394a connectors support 2 ports
Physical Spec
Form Factor ATX
Dimensions 12.0" x 9.6"
Power Pin 20 Pin
Packaging
Package Contents EP-8RDA3 PRO
User Manual
Driver Disk
Rear I/O Panel Shield
IDE/PATA Cable
FDD Cable
SATA Cable
4-pin to SATA Power Cable
IEEE 1394 Bracket
And i also looked this compatibility chart here at...
http://www.amdboard.com/epox_amd_cpu.htm
...but im not sure exactly what it means as far as what parts will work with it.
Latest posts
