Hello;
I would like to see a test at Tomshardware which shows at what point 5400rpm drives with high data-density per platter become faster than 7200 rpm drives with lower data-density.
To test this, we should make sure that all drives tested have the same amount of platters and heads. The total storage capacity is of no importance to test this.
For example:
If we would test 4 drives:
1. a 7200rpm drive with ONE 20Gb platter and 2 heads
2. a 7200rpm drive with ONE 40Gb platter " " "
3. a 5400rpm drive with ONE 60Gb platter " " "
4. a 5400rpm drive with ONE 80Gb platter " " "
Would the 5400rpm drives perform better than either of the 7200rpm drives which have lower data density?
I like quiet machines. That's why I would like to know.
I currently have an IBM 13,5Gb 7200rpm harddisk, which is rather noisy.
I was thinking: Current 5400rpm drives have data-densities of 40, 60 or even 80Gb per platter. COULD IT BE THAT THESE DRIVES ARE FASTER THAN MY CURRENT 7200 RPM DRIVE? Although they have a lower rpm, their data density must make up for this at one point sooner or later, right?
Cheers from Belgium;
For example:
