Hi! I recently bought an ID Cooling Auraflow x 120 (120mm radiator)and it has so many pins and connectors and I do not know which connector goes to which.
Apparently my motherboard only has two fan connectors one is named CPU_FAN and CHA_FAN
In the AIO, there are two cables from the PUMP
The first one - its a cable that looks like a female connector with 3 holes in it. Where does this go? Do I connect this directly to my CPU_FAN on the motherboard or to the CHA_FAN on my motherboard? (It also came with an adaptor that can be connected to the SATA Powersupply. (If I am not mistaken, I do not know if the pump has to be connected to the SATA or directly into the motherboard).
The 2nd one looks like the RGB connector and it looks like a 4 pin male connector which can be connected to a LED adaptor/controller that came in with the cooler
There are also two wires that came in with the FAN
One that looks like a female connector that has 4 holes on it ( similar to the female connector on the pump which only has 3 holes) where do I connect this also? to the CPU_FAN or to the CHA_FAN on my motherboard?
The 2nd one looks similar to the 2nd cable of the pump a cable that is male and has 4 pins (im guessing its also the LED connector).
