Question Which case is better in terms of cooling and noise generation ?
Arno__Dorian
80
Hi guys, I am confused between buying the Corsair 780T case and the CoolerMaster H500P Mesh case . Which do you think is better in terms of cooling and noise generation ? Assuming all fan slots are occupied except one where a liquid cooler radiatior is placed as exhaust . My GPU is Zotac rtx 2080 AMP and CPU is intel Core i7 8700 ( non k ) Any suggestions will be much appreciated . Thank you :)
Reactions: AdineX2
The H500P would probably have a slight advantage in cooling and noise since it has (2) 200mm fans up front to pull in cool air. The fans don't have to spin as fast to pull in air, so less noise. Also, you may have a hard time finding a 780T. It is an older case and Corsair has discontinued production.
