[SOLVED] Which CPUs will work with my motherboard ?
May 7, 2021
Go to the motherboard's manufacturer's website.
Using your motherboard's model number and revision number look for the supported CPU's.
Also check the manufacturer's FAQs and Forums (if any).
Look for what is said as well as what is "not said".
Read the motherboard's User Guide/Manual. Pay close attention to all footnotes, fine print, and caveats.
Check the QVLs (Qualified Vendor's List).
Details matter.
Details matter.
