I've just built my first pc and everything is working well EXCEPT my monitor has these fuzzy lines going across the screen diagonally. My best guess (I'm still new at this) is the graphics card cant keep up with the pixel demand.
I've updated all the drivers (multiple times) done factory resets, even removed and reset the physical card, and no difference. (as well as the memory)
2 things of note; 1. the pc works perfect on my tv (4k, 30hz) 2. during the install process for the driver(s) the lines go away UNTIL I obey the prompt to restart the computer, then the lines return.
I've tried to look up this problem specifically and have had no luck. My best guess, is I need a newer/more powerful GPU. I'd appreciate any input at this point. (i.e. which GPU is the least powerful that would still give work perfect, considering other parts to replace, trying to fix software before going through the hardware, etc.)
AMD Ryzen7 3700 3.6 GHz 8-core CPU
Deepcool assassin III 90.37 CFM CPU cooler
MSI MAG B550M mortar Wi-Fi micro ATX AM4 motherboard
G. skill Aegis 8 GB (1x8GB) DDR4 3000 CL16 memory (two of them)
Deepcool DA-N 600 W 80+ Bronze certified ATX PSU
Radeon RX 570 GPU
ASUS TUF Gaming 32" WQHD (2560 x 1440), 165Hz HDMI
THANKS!
Radeon RX 570 GPU
THANKS!
