[SOLVED] Which has more accurate temp readings speccy or aida64 extreme.
geoiii
Ryzen 5 3600x auto overclocked. Cooler Master hyper 212 and air intake right above.
I had both programs running while aida64 was doing its thing.
After 10 mins cpu stress test. I saw speccy jump to over 80 while aida64 never got above 44.
I hope you're right. I think 44 is very cool during test. I guess my cooling config is working.
You are not the first having false temperature indication using speccy especially using a Ryzen CPU. You can use AMD's software Ryzen Master or even better Hardware Info 64 to monitor the CPU temperature.
