[SOLVED] Which monitor should i choose ! ? help
Feb 12, 2020
So ...
i've seen reviews of LG 24GL600F 144 Hz and Sceptre 25" 165 hz E258B-1658A , the only thing that i'm wondering about is colors , the design or the refresh rate doesn't matter to me that much , the price is almost the same and budget friendly , but am kinda confused if i should go for LG or Scepter
You're not gonna get the best colors for either since they're both TN panel based. Though I'd prefer getting the Scepter over the LG since it's bigger and looks like a better quality build.
If you want the best colors you'll have to go with an IPS panel type - or the middle ground panel type: VA.
Here's a link on the difference between the 3 main panel types:
https://www.gamingscan.com/ips-vs-tn-vs-va/
