I have the Asus Rog Strix Z270e. It has a built in wifi card that gets 100 percent signal strength but the ping is always high. I bought over 8 different PCIe wifi cards. Each one gets 88 signal strength and the ping is amazing but I get lag spikes. It is like the motherboard is bottlenecking the PCIe wifi card. I did disable the built in card in the bios to see if that caused any issues and the problem is still the same. Does this motherboard just only work with the internal wifi card and just is sensitive to the PCIe cards? Is there a way I can take the built in wifi card out and replace it with an Intel chip? I used Netsh wlan show interface on CMD to test the signal strengths.
