Hello all,
This is my Z390 Motherboard:
https://www.newegg.com/p/N82E16813144209
My ultimate goal is to fit 3 RTX 3090s on this Z390 Godlike motherboard for mining:
Today I tried an experiment. I have listed the PCI-E lanes numbers in the picture below for reference:
View: https://imgur.com/a/9N2Yzgy
Normally I put my 1 RTX 3090 on the PCIe lane #4 on the far right side --->>>, but today I moved it over to the PCIe lane#1 on the far left side <<<---
View: https://imgur.com/a/9pgzyNt
The problem is, every time i boot up my PC while the GPU is in PCIe lane#1, it brings me to this MOBO BIOS screen and WONT load into windows as normal (even after several restarts):
View: https://imgur.com/a/bQSro8y
According to the "Board Explorer", when the GPU is in PCIe lane #1, it wont even recognize that it is there (and also wont recognize the 2TB M.2 NVME to boot into):
Click the image below for more images:
View: https://imgur.com/a/KExRkxf
If you look closely at the images above it says that PCIe#1 lane is a "PCIe x 1 slot" while at the same time PCIe lanes #2,3,4 are ALL "PCIe x 16 slot"
I removed the GPU from my PCIe#1 lane and the GPU works perfectly fine installed in PCIe lanes #2,3,4 (just not the lane #1 and I dont know why)
These are the pictures below of the GPU working fine with the other lanes and also recognizing the 2TB M.2 NVME to boot into:
View: https://imgur.com/a/POfXEcC
So my question is,
So my question is,
- Why doesnt the GPU boot into Windows when it is in PCIe#1 lane? And why it doesnt recognize my 2TB M.2 NVME when its in that lane?
- Why does the Z390 Godlike motherboard say that PCIe#1 lane is a "PCIe x 1 slot" while at the same time PCIe lanes #2,3,4 are ALL "PCIe x 16 slot"?
- Why does my PC boot normally into Windows and also recognize the 2TB M.2 NVME while only in PCIe lanes #2,3,4?
- *How do I make my RTX 3090 GPU work with the Z390 Motherboard while the GPU is inserted into PCIe#1 lane?
