Question Why is my Xfx R9 270x stuck in overheat mode (300mhz)
May 10, 2020
4
Before I get the equivalent of level 1 tech support answers.
Yes ive reinstalled drivers
Yes I tried unplugging and powering down the device and restarting (this one is for laughs)
Yes I've updated the Vbios
Yes I've replaced the thermal paste
Yes I've looked for the infamous PP_CNescapeinput bug
Yes I've scoured the internet for a solution
Yes I've tried limiting the initial core clock
Yes I've tried Manually Restarting the driver. (Note that this does temporarily correct the issue only to happen again in 15 minutes)
So having taken note that all of these steps have been taken, This issue occurs playing any complex 3d rendered game of any type old or new. After about 15 minutes the temperature of the gpu spikes at 101c initiating system protection limits dropping the core clock cap to 450 mhz then about 5-10 minutes later after reducing temperatures to 80c it drops down to 300.
One thing to note about this cards vbios is that it has 3 core clock states. State 1 is 1050 2 is 450 and 3 is 300. Upon cooling down to as low as even 32c the card will never return to state 2 or 1, unless the driver is reset. In the initial state i am getting fps of about 75-160 and even still in state 2 it doesnt drop below 70 fps but state 3 I get a whopping 18 at most. It is also notable that State 3 is considered to be idle state but it still registers 100 percent usage.
This behavior is consistent through Wolcen, Smite, FFXIV, RoI, Warframe, and even World of Warcraft. This games all have variant workloads but the card yields the same behavior in the same time intervals no matter what the game or the settings.
I will attach the dxdiag in a later post.
Side Note, I am Running Windows 10, using Latest Radeon Suite, MSI afterburner, GPU-Z. At one point I was using Wattman and I have found traces of evidence that may correlate to this behavior starting when I installed wattman. So I am wondering if there is a bad reg key after long since uninstalling it.
System Information
Time of this report: 5/10/2020, 17:58:01
Machine name: ADAM-PC
Machine Id: {86A1F78D-7E39-42A1-8013-4D5FDB5A3457}
Operating System: Windows 10 Home 64-bit (10.0, Build 18363) (18362.19h1_release.190318-1202)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTeK Computer INC.
System Model: CG1330
BIOS: BIOS Date: 01/28/11 09:50:41 Ver: 05.01 (type: BIOS)
Processor: AMD Phenom(tm) II X6 1035T Processor (6 CPUs), ~2.6GHz
Memory: 8192MB RAM
Available OS Memory: 7936MB RAM
Page File: 7231MB used, 4704MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: Unknown
DxDiag Version: 10.00.18362.0387 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: No problems found.
Sound Tab 5: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon R9 200 Series
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon Graphics Processor (0x6810)
DAC type: Internal DAC(400MHz)
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_1002&DEV_6810&SUBSYS_92751682&REV_00
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 5995 MB
Dedicated Memory: 2027 MB
Shared Memory: 3967 MB
Current Mode: 1920 x 1080 (32 bit) (59Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
Color Primaries: Red(0.645508,0.336914), Green(0.328125,0.615234), Blue(0.146484,0.055664), White Point(0.313477,0.329102)
Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
Monitor Name: Generic PnP Monitor
Monitor Model: C24F390
Monitor Id: SAM0D2C
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\aticfx64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdxc64.dll
Driver File Version: 26.20.15019.19000 (English)
Driver Version: 26.20.15019.19000
DDI Version: 12
Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 2.6
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: 2/27/2020 8:00:00 PM, 1943472 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71EE2-2B50-11CF-0A3F-DE88BBC2D735}
Vendor ID: 0x1002
Device ID: 0x6810
SubSys ID: 0x92751682
Revision ID: 0x0000
Driver Strong Name: oem33.inf:cb0ae4140a32e68b:ati2mtag_R575:26.20.15019.19000😛CI\VEN_1002&DEV_6810&REV_00
Rank Of Driver: 00CF2000
Video Accel: Unknown
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeVC1_VLD DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT
Deinterlace Caps: n/a
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO MaxPlanes: 1
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
PanelFitter Caps: Not Supported
PanelFitter Stretch: Not Supported
Sound Devices
Description: Speakers (VIA HD Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_0397&SUBSYS_1043836C&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: viahduaa.sys
Driver Version: 6.00.0011.0800 (English)
WHQL Logo'd: Yes
Date and Size: 6/15/2015 12:00:00 AM, 701136 bytes
Other Files:
Driver Provider: VIA Technologies, Inc.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: 3 - C24F390 (AMD High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: AtihdWT6.sys
Driver Version: 10.00.0001.0012 (English)
WHQL Logo'd: Yes
Date and Size: 7/10/2019 12:00:00 AM, 108152 bytes
Other Files:
Driver Provider: Advanced Micro Devices
Cap Flags: 0xF1F
HW Memory: 0
Description: Headphone (VIA HD Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: SPDIF Interface (TX0) (VIA HD Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: SPDIF Interface (TX1) (VIA HD Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (VIA HD Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Date and Size: 8/6/2015 01:05:27, 701136 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: CORSAIR NIGHTSWORD RGB Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B5C
FF Driver: n/a
Device Name: CORSAIR K70 RGB MK.2 Mechanical Gaming Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x1B49
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Corsair K70 RGB MK.2 Mechanical Gaming Keyboard
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4397
| Matching Device ID: USB\ROOT_HUB
| Service: usbhub
| Driver: usbhub.sys, 3/19/2019 00:43:43, 545592 bytes
| Driver: usbd.sys, 3/19/2019 00:43:43, 33592 bytes
+-+ USB Composite Device
| | Matching Device ID: USB\COMPOSITE
| | Service: usbccgp
| | Driver: usbccgp.sys, 3/15/2020 22:54:40, 183608 bytes
| +-+ Corsair K70 RGB MK.2 Mechanical Gaming Keyboard
| | | Matching Device ID: usb\vid_1b1c&pid_1b49&mi_00
| | | Service: HidUsb
| | | Driver: CUEInstallPrompt.exe, 11/2/2018 15:09:48, 1079184 bytes
| | | Driver: hidusb.sys, 3/15/2020 22:54:40, 45568 bytes
| | | Driver: hidclass.sys, 3/15/2020 22:54:40, 211968 bytes
| | | Driver: hidparse.sys, 3/15/2020 22:54:40, 46080 bytes
| | | Driver: CorsairHIDCoInstaller64.dll, 11/2/2018 15:09:46, 130440 bytes
| | +-+ HID Keyboard Device
| | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 3/19/2019 00:43:43, 46592 bytes
| | | | Driver: kbdclass.sys, 3/19/2019 00:43:43, 70968 bytes
| | +-+ HID-compliant mouse
| | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | Service: mouhid
| | | | Driver: mouhid.sys, 3/19/2019 00:43:43, 35840 bytes
| | | | Driver: mouclass.sys, 3/19/2019 00:43:43, 66872 bytes
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4398
| Service: usbhub
| | Service: usbccgp
| +-+ USB Input Device
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | | Service: mouhid
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
| Vendor/Product ID: 0x1B1C, 0x0000
| Service: kbdhid
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 17.8 GB
Total Space: 121.6 GB
File System: NTFS
Model: Samsung SSD 840 PRO Series ATA Device
Drive: D:
Free Space: 44.8 GB
Total Space: 143.1 GB
File System: NTFS
Model: WDC WD1500AHFD-00RAR1 ATA Device
Drive: E:
Free Space: 0.1 GB
Total Space: 0.5 GB
File System: NTFS
Model: MKNSSDEC240GB ATA Device
Drive: F:
Free Space: 36.1 GB
Total Space: 228.4 GB
File System: NTFS
System Devices
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_83891043&REV_3C\3&267A616A&0&A0
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00\3&267A616A&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_9600&SUBSYS_83881043&REV_00\3&267A616A&0&00
Driver: n/a
Name: ATI Radeon 3000 Graphics
Device ID: PCI\VEN_1002&DEV_9616&SUBSYS_83881043&REV_00\4&52E5CC6&0&2808
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00\3&267A616A&0&C4
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_83891043&REV_00\3&267A616A&0&98
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 475144 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 545592 bytes
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_83891043&REV_00\3&267A616A&0&90
Device ID: PCI\VEN_1022&DEV_9603&SUBSYS_83881043&REV_00\3&267A616A&0&10
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.18362.0752 (English), 4/16/2020 03:44:43, 437560 bytes
Name: High Definition Audio Bus
Device ID: PCI\VEN_1002&DEV_960F&SUBSYS_83881043&REV_00\4&52E5CC6&0&2908
Driver: C:\WINDOWS\system32\DRIVERS\amdkmafd.sys, 8.14.0001.6003 (English), 8/18/2016 08:41:28, 49448 bytes
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.18362.0693 (English), 3/15/2020 22:54:37, 114688 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:37, 98304 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:37, 390656 bytes
Device ID: PCI\VEN_1043&DEV_9602&SUBSYS_83881043&REV_00\3&267A616A&0&08
Name: AMD Radeon R9 200 Series
Device ID: PCI\VEN_1002&DEV_6810&SUBSYS_92751682&REV_00\4&2A1FC852&0&0010
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\aticfx32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:34, 1586448 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\aticfx64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:36, 1943472 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_nv.dat, 3/2/2020 10:52:16, 458112 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdefctb.dat, 3/2/2020 10:51:36, 281101 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdxn32.dll, 8.14.0010.0053 (English), 3/2/2020 12:36:22, 37147664 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdxn64.dll, 8.14.0010.0053 (English), 3/2/2020 12:36:22, 41851408 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_vg20.dat, 3/2/2020 10:52:16, 379200 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_vg20_nd.dat, 3/2/2020 10:52:16, 383264 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdave32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:22, 118224 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdave64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:22, 133312 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_rv.dat, 3/2/2020 10:52:16, 356992 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amde40a.dat, 3/2/2020 10:51:36, 173344 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_gl_nd.dat, 3/2/2020 10:52:16, 380448 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdmmcl.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:12, 125456 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiumdag.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:42, 10461504 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiumdva.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:44, 13162976 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativce02.dat, 3/2/2020 10:52:16, 100832 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_cik.dat, 3/2/2020 10:52:16, 234676 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_cik_nd.dat, 3/2/2020 10:52:16, 234416 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdmmcl6.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:12, 147472 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiumd64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:40, 13159336 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiumd6a.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:42, 13859136 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amduve64.dll, 17.01.0006.0000 (English), 3/2/2020 12:35:30, 171416 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amduve32.dll, 17.01.0006.0000 (English), 3/2/2020 12:35:30, 147512 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\AMDh265Enc32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:26, 1063232 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\AMDh265Enc64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:26, 1324032 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ccc2_install.exe, 8.911.0003.3000 (English), 3/2/2020 12:36:54, 221569112 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amde34b.dat, 3/2/2020 10:51:36, 166624 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amde34a.dat, 3/2/2020 10:51:36, 166624 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_stn_nd.dat, 3/2/2020 10:52:16, 278560 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdvlk32.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:18, 20600848 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdvlk64.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:20, 24173072 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amd-vulkan32.json, 3/2/2020 10:51:36, 703 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amd-vulkan64.json, 3/2/2020 10:51:36, 703 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_el_nd.dat, 3/2/2020 10:52:16, 375968 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdicdxx.dat, 3/2/2020 10:51:58, 1154422 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiicdxx.dat, 3/2/2020 10:52:08, 737410 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdocl12cl.dll, 0.08.0000.0000 (English), 3/2/2020 12:36:14, 21293072 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdocl12cl64.dll, 0.08.0000.0000 (English), 3/2/2020 12:36:16, 26740752 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_FJ.dat, 3/2/2020 10:52:16, 268244 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_FJ_nd.dat, 3/2/2020 10:52:16, 267984 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdxc32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:32, 27188592 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdxc64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:32, 31250864 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_cz_nd.dat, 3/2/2020 10:52:16, 272928 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amde31a.dat, 3/2/2020 10:51:36, 159072 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\AMDhwDecoder_32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:56, 245776 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\AMDhwDecoder_64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:58, 299024 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\AMDh264Enc32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:24, 1625768 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\AMDh264Enc64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:24, 1853440 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativce03.dat, 3/2/2020 10:52:16, 160768 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_vi.dat, 3/2/2020 10:52:16, 325188 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\ativvaxy_vi_nd.dat, 3/2/2020 10:52:16, 324928 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdhdl32.dll, 3/2/2020 12:35:26, 330888 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdhdl64.dll, 3/2/2020 12:35:26, 433760 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdocl.dll, 10.00.3004.0008 (English), 3/2/2020 12:36:14, 65471504 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdocl64.dll, 10.00.3004.0008 (English), 3/2/2020 12:36:16, 79088144 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdmantle32.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:04, 29769744 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\amdmantle64.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:06, 34392080 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiesrxx.exe, 26.20.15019.19000 (English), 3/2/2020 12:36:38, 522256 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiu9pag.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:40, 166048 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atigktxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:40, 206864 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiglpxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:42, 143888 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiuxpag.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:44, 185744 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiu9p64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:40, 202880 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atiuxp64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:44, 220584 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atig6pxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:40, 168464 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atig6txx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:40, 239632 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atidxx32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:36, 21998576 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atidxx64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:38, 26242936 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atioglxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:48, 41547280 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atio6axx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:46, 49848848 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atikmdag.sys, 26.20.15019.19000 (English), 3/2/2020 12:36:42, 65731088 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\u0352369.inf_amd64_275818c45a90b362\B352355\atikmpag.sys, 26.20.15019.19000 (English), 3/2/2020 12:36:44, 589840 bytes
Driver: C:\WINDOWS\system32\aticfx64.dll, 8.17.0010.1680 (English), 3/2/2020 12:36:32, 176616 bytes
Driver: C:\WINDOWS\system32\amdihk64.dll, 2.00.0000.1788 (English), 3/2/2020 12:36:00, 195656 bytes
Driver: C:\WINDOWS\system32\amd_comgr.dll, 3/2/2020 12:36:24, 62865424 bytes
Driver: C:\WINDOWS\system32\amdlogum.exe, 3/2/2020 12:36:02, 464912 bytes
Driver: C:\WINDOWS\system32\amdhip64.dll, 10.00.3004.0008 (English), 3/2/2020 12:35:56, 78648848 bytes
Driver: C:\WINDOWS\system32\EEURestart.exe, 3/2/2020 12:36:58, 426512 bytes
Driver: C:\WINDOWS\system32\atiadlxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:30, 1728528 bytes
Driver: C:\WINDOWS\system32\amdave64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:22, 133312 bytes
Driver: C:\WINDOWS\system32\amdpcom64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:28, 127104 bytes
Driver: C:\WINDOWS\system32\atimpc64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:38, 127104 bytes
Driver: C:\WINDOWS\system32\atimuixx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:44, 134160 bytes
Driver: C:\WINDOWS\system32\atisamu64.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:50, 157200 bytes
Driver: C:\WINDOWS\system32\atiumd6a.cap, 3/2/2020 10:52:14, 3437632 bytes
Driver: C:\WINDOWS\system32\ativvsva.dat, 1/13/2015 16:25:00, 157144 bytes
Driver: C:\WINDOWS\system32\ativvsvl.dat, 1/13/2015 16:25:00, 204952 bytes
Driver: C:\WINDOWS\system32\amfrt64.dll, 1.04.0016.0000 (English), 3/2/2020 12:36:28, 4583440 bytes
Driver: C:\WINDOWS\system32\amdmcl64.dll, 1.06.0000.0000 (English), 3/2/2020 12:36:06, 551952 bytes
Driver: C:\WINDOWS\system32\dgtrayicon.exe, 3/2/2020 12:36:56, 491536 bytes
Driver: C:\WINDOWS\system32\AMDKernelEvents.man, 3/2/2020 10:51:58, 69770 bytes
Driver: C:\WINDOWS\system32\vulkan-1.dll, 1.02.0131.0000 (English), 3/2/2020 12:37:08, 1083320 bytes
Driver: C:\WINDOWS\system32\vulkan-1-999-0-0-0.dll, 1.02.0131.0000 (English), 3/2/2020 12:37:08, 1083320 bytes
Driver: C:\WINDOWS\system32\vulkaninfo.exe, 1.02.0131.0000 (English), 3/2/2020 12:37:10, 1763344 bytes
Driver: C:\WINDOWS\system32\vulkaninfo-1-999-0-0-0.exe, 1.02.0131.0000 (English), 3/2/2020 12:37:10, 1763344 bytes
Driver: C:\WINDOWS\system32\GameManager64.dll, 3/2/2020 12:37:00, 489488 bytes
Driver: C:\WINDOWS\system32\amdmiracast.dll, 3/2/2020 12:35:28, 544696 bytes
Driver: C:\WINDOWS\system32\amdlvr64.dll, 1.00.0016.0000 (English), 3/2/2020 12:36:04, 939536 bytes
Driver: C:\WINDOWS\system32\RapidFireServer64.dll, 1.02.0000.0015 (English), 3/2/2020 12:37:06, 45072 bytes
Driver: C:\WINDOWS\system32\Rapidfire64.dll, 1.02.0001.0286 (English), 3/2/2020 12:37:06, 572432 bytes
Driver: C:\WINDOWS\system32\amdxc64.dll, 8.18.0010.0349 (English), 3/2/2020 12:36:20, 118800 bytes
Driver: C:\WINDOWS\system32\amf-mft-mjpeg-decoder64.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:34, 1684384 bytes
Driver: C:\WINDOWS\system32\mcl64.dll, 26.20.15019.19000 (English), 3/2/2020 12:37:04, 89104 bytes
Driver: C:\WINDOWS\system32\kapp_ci.sbin, 3/2/2020 10:52:22, 125488 bytes
Driver: C:\WINDOWS\system32\samu_krnl_ci.sbin, 9/18/2019 17:33:12, 154384 bytes
Driver: C:\WINDOWS\system32\samu_krnl_isv_ci.sbin, 9/18/2019 17:33:12, 138832 bytes
Driver: C:\WINDOWS\system32\kapp_si.sbin, 9/18/2019 17:33:10, 121168 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 2.02.0001.0000 (English), 3/2/2020 12:36:28, 133136 bytes
Driver: C:\WINDOWS\system32\clinfo.exe, 3/2/2020 12:36:54, 342544 bytes
Driver: C:\WINDOWS\system32\mantle64.dll, 26.20.15019.19000 (English), 3/2/2020 12:37:02, 182288 bytes
Driver: C:\WINDOWS\system32\mantleaxl64.dll, 26.20.15019.19000 (English), 3/2/2020 12:37:02, 160784 bytes
Driver: C:\WINDOWS\system32\detoured.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:56, 18760 bytes
Driver: C:\WINDOWS\system32\amdgfxinfo64.dll, 3/2/2020 12:35:54, 482320 bytes
Driver: C:\WINDOWS\system32\atieah64.exe, 3/2/2020 12:36:36, 449552 bytes
Driver: C:\WINDOWS\system32\atieclxx.exe, 26.20.15019.19000 (English), 3/2/2020 12:36:38, 758800 bytes
Driver: C:\WINDOWS\system32\atiapfxx.blb, 3/2/2020 10:52:06, 543136 bytes
Driver: C:\WINDOWS\system32\atig6txx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:40, 239632 bytes
Driver: C:\WINDOWS\system32\atidxx64.dll, 3/2/2020 12:36:36, 122384 bytes
Driver: C:\WINDOWS\system32\ati2erec.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:30, 68624 bytes
Driver: C:\WINDOWS\system32\atidemgy.dll, 4.05.7363.32734 (English), 3/2/2020 12:36:34, 466960 bytes
Driver: C:\WINDOWS\SysWOW64\aticfx32.dll, 8.17.0010.1680 (English), 3/2/2020 12:36:32, 155968 bytes
Driver: C:\WINDOWS\SysWOW64\amdihk32.dll, 2.00.0000.1788 (English), 3/2/2020 12:35:58, 165256 bytes
Driver: C:\WINDOWS\SysWOW64\amd_comgr32.dll, 3/2/2020 12:36:26, 52401168 bytes
Driver: C:\WINDOWS\SysWOW64\atiadlxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:32, 1241104 bytes
Driver: C:\WINDOWS\SysWOW64\atiadlxy.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:32, 1241104 bytes
Driver: C:\WINDOWS\SysWOW64\amdave32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:22, 118224 bytes
Driver: C:\WINDOWS\SysWOW64\amdpcom32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:28, 106208 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsva.dat, 1/13/2015 16:25:00, 157144 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsvl.dat, 1/13/2015 16:25:00, 204952 bytes
Driver: C:\WINDOWS\SysWOW64\atimpc32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:38, 106208 bytes
Driver: C:\WINDOWS\SysWOW64\atisamu32.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:50, 134160 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdva.cap, 3/2/2020 10:52:16, 3471376 bytes
Driver: C:\WINDOWS\SysWOW64\amfrt32.dll, 1.04.0016.0000 (English), 3/2/2020 12:36:28, 4092944 bytes
Driver: C:\WINDOWS\SysWOW64\amdmcl32.dll, 1.06.0000.0000 (English), 3/2/2020 12:36:06, 381968 bytes
Driver: C:\WINDOWS\SysWOW64\vulkan-1.dll, 1.02.0131.0000 (English), 3/2/2020 12:37:08, 942168 bytes
Driver: C:\WINDOWS\SysWOW64\vulkan-1-999-0-0-0.dll, 1.02.0131.0000 (English), 3/2/2020 12:37:08, 942168 bytes
Driver: C:\WINDOWS\SysWOW64\vulkaninfo.exe, 1.02.0131.0000 (English), 3/2/2020 12:37:08, 1357840 bytes
Driver: C:\WINDOWS\SysWOW64\vulkaninfo-1-999-0-0-0.exe, 1.02.0131.0000 (English), 3/2/2020 12:37:08, 1357840 bytes
Driver: C:\WINDOWS\SysWOW64\GameManager32.dll, 3/2/2020 12:37:00, 372240 bytes
Driver: C:\WINDOWS\SysWOW64\amdlvr32.dll, 1.00.0016.0000 (English), 3/2/2020 12:36:02, 766992 bytes
Driver: C:\WINDOWS\SysWOW64\RapidFireServer.dll, 1.02.0000.0015 (English), 3/2/2020 12:37:06, 42000 bytes
Driver: C:\WINDOWS\SysWOW64\Rapidfire.dll, 1.02.0001.0286 (English), 3/2/2020 12:37:04, 483344 bytes
Driver: C:\WINDOWS\SysWOW64\amdxc32.dll, 8.18.0010.0349 (English), 3/2/2020 12:36:20, 103952 bytes
Driver: C:\WINDOWS\SysWOW64\amf-mft-mjpeg-decoder32.dll, 26.20.15019.19000 (English), 3/2/2020 12:35:34, 1363744 bytes
Driver: C:\WINDOWS\SysWOW64\mcl32.dll, 26.20.15019.19000 (English), 3/2/2020 12:37:04, 73744 bytes
Driver: C:\WINDOWS\SysWOW64\OpenCL.dll, 2.02.0001.0000 (English), 3/2/2020 12:36:26, 119312 bytes
Driver: C:\WINDOWS\SysWOW64\mantle32.dll, 26.20.15019.19000 (English), 3/2/2020 12:37:00, 151056 bytes
Driver: C:\WINDOWS\SysWOW64\mantleaxl32.dll, 26.20.15019.19000 (English), 3/2/2020 12:37:02, 136208 bytes
Driver: C:\WINDOWS\SysWOW64\detoured.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:56, 18760 bytes
Driver: C:\WINDOWS\SysWOW64\amdgfxinfo32.dll, 3/2/2020 12:35:54, 371728 bytes
Driver: C:\WINDOWS\SysWOW64\atieah32.exe, 3/2/2020 12:36:36, 343568 bytes
Driver: C:\WINDOWS\SysWOW64\atiapfxx.blb, 3/2/2020 10:52:06, 543136 bytes
Driver: C:\WINDOWS\SysWOW64\atigktxx.dll, 26.20.15019.19000 (English), 3/2/2020 12:36:40, 206864 bytes
Driver: C:\WINDOWS\SysWOW64\atidxx32.dll, 3/2/2020 12:36:34, 104976 bytes
Driver: C:\WINDOWS\system32\AMD\amdkmpfd\amdkmpfd.stz, 19.20.0001.0000 (English), 3/2/2020 12:36:00, 102824 bytes
Driver: C:\WINDOWS\system32\AMD\amdkmpfd\amdkmpfd.itz, 9/18/2019 17:32:56, 1999 bytes
Driver: C:\WINDOWS\system32\AMD\amdkmpfd\amdkmpfd.ctz, 9/18/2019 17:32:56, 8590 bytes
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_83A31043&REV_03\4&1708FA51&0&0050
Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 9.01.0409.2015 (English), 3/19/2019 00:43:41, 662528 bytes
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_00\3&267A616A&0&A4
Device ID: PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00\3&267A616A&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_9609&SUBSYS_83881043&REV_00\3&267A616A&0&50
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_83891043&REV_00\3&267A616A&0&99
Device ID: PCI\VEN_1002&DEV_4398&SUBSYS_83891043&REV_00\3&267A616A&0&91
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_4390&SUBSYS_83891043&REV_00\3&267A616A&0&88
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 10.00.18362.0693 (English), 3/15/2020 22:54:39, 16912 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 10.00.18362.0693 (English), 3/15/2020 22:54:39, 56632 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 10.00.18362.0693 (English), 3/15/2020 22:54:39, 30008 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ataport.sys, 10.00.18362.0693 (English), 3/15/2020 22:54:39, 222520 bytes
Device ID: PCI\VEN_1002&DEV_439C&SUBSYS_83891043&REV_00\3&267A616A&0&A1
Device ID: PCI\VEN_1002&DEV_AAB0&SUBSYS_AAB01682&REV_00\4&2A1FC852&0&0110
Device ID: PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00\3&267A616A&0&C0
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00\3&267A616A&0&C3
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_83891043&REV_00\3&267A616A&0&9A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.18362.0001 (English), 3/19/2019 00:43:43, 100664 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_83891043&REV_00\3&267A616A&0&92
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_836C1043&REV_00\3&267A616A&0&A2
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_83891043&REV_00\3&267A616A&0&A5
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_83891043&REV_00\3&267A616A&0&A3
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.18362.0267 (English), 3/15/2020 22:54:39, 19256 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.18362.0145
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.18362.0145
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.18362.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.18362.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.18362.0001
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.18362.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.18362.0001
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.18362.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.18362.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.18362.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.18362.0001
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.18362.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.18362.0001
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.18362.0001
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.18362.0001
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.18362.0753
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.18362.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.18362.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.18362.0001
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.18362.0001
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.18362.0001
ATI MPEG File Writer,0x00200000,1,0,atimpenc64.dll,
AMD Video Decoder,0x00200000,1,2,atimpenc64.dll,
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.18362.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.18362.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.18362.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.18362.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.18362.0001
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.18362.0001
DV Splitter,0x00600000,1,2,qdv.dll,10.00.18362.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.18362.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.18362.0001
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc64.dll,
AMD MJPEG Decoder,0x00200000,1,1,atimpenc64.dll,
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.18362.0001
Video Renderer,0x00800001,1,0,quartz.dll,10.00.18362.0001
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.18362.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.18362.0001
Video Renderer,0x00400000,1,0,quartz.dll,10.00.18362.0001
AMD Video Encoder,0x00200000,1,1,atimpenc64.dll,
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc64.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.18362.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.18362.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.18362.0001
AMD Video Scaler Filter,0x00200000,1,1,atimpenc64.dll,
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.18362.0001
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.18362.0001
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.18362.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.18362.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.18362.0001
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.18362.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.18362.0001
Null Renderer,0x00200000,1,0,qedit.dll,10.00.18362.0001
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.18362.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.18362.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.18362.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.18362.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.18362.0001
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.18362.0001
Wave Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.18362.0001
File stream renderer,0x00400000,1,1,quartz.dll,10.00.18362.0001
AMD Video Rotation Filter,0x00200000,1,1,atimpenc64.dll,
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.18362.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.18362.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.18362.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.18362.0001
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.18362.0001
File Source (URL),0x00400000,0,1,quartz.dll,10.00.18362.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.18362.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.18362.0001
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.18362.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.18362.0001
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.18362.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.18362.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.18362.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.18362.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.18362.0001
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.18362.0145
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.18362.0145
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.18362.0001
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.18362.0001
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.18362.0001
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.18362.0001
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.18362.0001
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.18362.0001
Audio Capture Sources:
Microphone (VIA HD Audio),0x00200000,0,0,qcap.dll,10.00.18362.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.18362.0657
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.18362.0657
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.18362.0657
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.18362.0001
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.18362.0001
WDM Streaming Capture Devices:
,0x00000000,0,0,,
VIA HD Audio Input,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
WDM Streaming Rendering Devices:
AMD HD Audio HDMI out #2,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
VIA HD Audio Output 2,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
HD Audio digital out,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
VIA HD Audio Headphone,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.18362.0001
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.18362.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.18362.0001
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,msvidctl.dll,6.05.18362.0001
Encrypt/Tag,0x00200000,0,0,,
PTFilter,0x00200000,0,0,,
XDS Codec,0x00200000,0,0,,
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (VIA HD Audio),0x00200000,1,0,quartz.dll,10.00.18362.0001
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.18362.0001
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: 3 - C24F390 (AMD High Definition Audio Device),0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: Headphone (VIA HD Audio),0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: SPDIF Interface (TX0) (VIA HD Audio),0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: Speakers (VIA HD Audio),0x00200000,1,0,quartz.dll,10.00.18362.0001
DirectSound: SPDIF Interface (TX1) (VIA HD Audio),0x00200000,1,0,quartz.dll,10.00.18362.0001
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.18362.0815
mfreadwrite.dll, 10.00.18362.0719
mfcaptureengine.dll, 10.00.18362.0001
mfsensorgroup.dll, 10.00.18362.0628
windows.media.dll, 10.00.18362.0145
frameserver.dll, 10.00.18362.0628
fsclient.dll, 10.00.18362.0628
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
AMD D3D11 Hardware MFT Playback Decoder, {17796AEB-0F66-4663-B8FB-99CBEE0224CE}, 0x4, 8, amdhwdecoder_64.dll, 26.20.15019.19000
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.18362.0753
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.18362.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.18362.0001
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.18362.0753
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.18362.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.18362.0001
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.18362.0001
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.18362.0001
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.18362.0001
HEIFImageExtension
VP9VideoExtensionDecoder
WebpImageExtension
Video Encoders:
AMDh264Encoder, {ADC9BC80-0F41-46C6-AB75-D693D793597D}, 0x4, 8, amdh264enc64.dll, 26.20.15019.19000
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.18362.0001
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.18362.0001
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.18362.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.18362.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.18362.0001
HEIFImageExtension
VP9VideoExtensionEncoder
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.18362.0001
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.18362.0001
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.18362.0001
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.18362.0001
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.18362.0001
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.18362.0387
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.18362.0719
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.18362.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.18362.0145
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.18362.0778
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.18362.0815
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.18362.0815
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.18362.0145
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.18362.0001
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.18362.0778
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.18362.0778
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.18362.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.18362.0815
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.18362.0815
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.18362.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.18362.0001
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.18362.0815
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.18362.0815
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.18362.0719
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.18362.0145
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.18362.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.18362.0001
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.18362.0145
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.18362.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.18362.0001
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.18362.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.18362.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.18362.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.18362.0815
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.18362.0753
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 2274154645535315025, type 4
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: RadeonSoftware.exe
P2: 10.1.2.1788
P3: 5e59a285
P4: StackHash_890d
P5: 10.0.18362.815
P6: b29ecf52
P7: c0000374
P8: PCH_9F_FROM_ntdll+0x000000000009CBC4
P9:
P10:
+++ WER1 +++:
Fault bucket 2148220840094382143, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: superposition.exe
P2: 1.1.0.0
P3: 10.0.18363.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 1903214705929002968, type 5
Event Name: CLR20r3
Cab Id: 0
Problem signature:
P1: Corsair.Service.DisplayAdapter
P2: 3.27.0.7
P3: 5e58dc27
P4: System.Management
P5: 4.8.3752.0
P6: 5c7a241f
P7: 8a
P8: 51
P9: PSZQOADHX1U5ZAHBHOHGHLDGIY4QIXHX
P10:
+++ WER3 +++:
Fault bucket 1638950011265988467, type 5
Cab Id: 0
Problem signature:
P2: 10.1.2.1788
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Fault bucket 107516090690, type 1
Cab Id: 0
Problem signature:
P1: jucheck.exe
P2: 2.8.60.27
P3: 55c116b1
P4: jucheck.exe
P5: 2.8.60.27
P6: 55c116b1
P7: 40000015
P8: 00052d24
P9:
P10:
+++ WER5 +++:
Fault bucket 1239812814213135674, type 5
Cab Id: 0
Problem signature:
P1: ffxiv_dx11.exe
P2: 1.0.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER6 +++:
Fault bucket 2039439390699284962, type 5
Event Name: RADAR_PRE_LEAK_WOW64
Cab Id: 0
Problem signature:
P1: MSIAfterburner.exe
P2: 4.6.1.15561
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P1: jucheck.exe
P2: 2.8.60.27
P3: 55c116b1
P4: jucheck.exe
P5: 2.8.60.27
P6: 55c116b1
P7: 40000015
P8: 00052d24
P9:
P10:
+++ WER8 +++:
Fault bucket 2135597896679270959, type 5
Cab Id: 0
Problem signature:
P1: Smite.exe
P2: 1.0.10897.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER9 +++:
Fault bucket 1354129374200491809, type 5
Cab Id: 0
Problem signature:
P1: Microsoft.Photos.exe
P2: 2020.19111.24110.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
I definitely did both. I could try ddu again after given all other steps that I have tried since then may contribute to the solutions.
Edit: Just reinstalled clean with DDU, same behavior except even faster progression. Started at 55c hit 101 in less than 10 min
An interesting addition to the information I had earlier. I underclocked the card down to the levels in which it sustains during overheat mode, so 300/150 and it still hit 101c. The crazy thing about that was while the card was completely underclocked i still got 60 fps, but once the card initiated failsafe mode, it dropped to 15.
Dont know if that points to a bad card itself or bad regkey/driver situation.
